Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Roof Forum >
Can there be to many types of ventilation?
Previous Topic: Re-education in 3 tab nailing - Topic - Next Topic: Pabco? New TopicReply to TopicShare Topic
Posted By
Virginia Beach, va
Currently offline offline
Thread Start First Page
[#1] Posted: 07/27/2009 - 10:36:00 AM
Just curious if having multiple venting systems on the same roof is beneficial. This roof had soffit and ridge vents, turbine vents, and fan assisted gable vent. Is there a point of diminishing return with to many systems working at the same time, or will they all compliment each other?
www.safehousepropertyinspections.com
Virginia Beach Home Inspector
View Profile
Collins, NY
[#2] Posted: 07/27/2009 - 11:04:22 AM
Most likely the original wasn't functioning well so someone added another, this didn't help so they added another. This is wrong. Mixing vent systems has consequences, usually bad. One attic space should have one vent system, one roof system with multiple attics each with a different system would be OK and may even be preferable given the right circumstances.
Tom
Tom
Dr Joe Lstiburek
View Profile
Little Rock, AR
[#3] Posted: 07/27/2009 - 11:05:37 AM
Yes, you can have too many different types of ventilation that do not work well together. In a well designed system, the natural convection currents formed when warm air escapes out the top near the ridge will pull in cooler air at the soffitt vents. With competing types of ventilation near the ridge, air will tend to be pulled in via the path of least resistance. For example, the power gable vent will pull air in from the turbine or ridge vent rather than at the soffitt line. In effect, you're short-circuiting proper airflow from lower in the attic and you will have some dead air space.
Kevin
"Politicians are interested in people. Not that it is always a virtue; fleas are interested in dogs." P.J. O'Rourke
View Profile
[#4] Posted: 07/27/2009 - 11:10:15 AM
Soffit and ridge vents are all that are needed. The turbine and power vents in some scenarios could actually interfere with the flow of air through the attic when ridge vents are installed.
The gable power vent would actually be sucking air in through the ridge, turbine and soffit vents. I can't really think of any positive outcome with this type of venting. The air flow should start at the soffit and exit out the highest point which should be the ridge vents.
Scott Patterson
View Profile
Kenmore, WA
[#5] Posted: 07/27/2009 - 12:46:35 PM
The guy that put in all of those systems probably wears both belt and suspenders on his pants.
OT - OF!!!
M.
View Profile
Elizabethtown, PA
[#6] Posted: 08/02/2009 - 12:00:28 PM
Mixed ventilation types can also void the shingle warranties.
Matthew Steger
WIN
"Common sense is not so common."
View Profile
Barrington, IL
[#7] Posted: 08/05/2009 - 8:21:20 PM
In regards to passive venting of an attic, I've never seen problems from too much. I'd be interested if anyone can produce a published, independent study on such an installation.
Eric Barker
ebarker@morainewoods.com
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
