| Posted By |
Samantha, AL Posts: 1569
| offline |
Chicago, IL Posts: 9507
| offline |
Do you find repairs like this?
[#2] Posted: 04/10/2010 - 05:42:27 AM |  | |
At least it wasn't a big goober of roof cement.
Kurt in Chicago
Evanston, Illinois Posts: 408
| offline |
[#3] Posted: 04/10/2010 - 05:45:29 AM |  | |
That is almost the exact detail used to wrap 4"-16" vent penetrations on a flat roof, only the rain diverter is metal and caulked in place. I think the neoprene would be more effective, but I've never seen it on a pitched roof.
Of course it's not going to do anything to help the rip at the base of the older neoprene flashing shown in your 1st pic.
| Cary |
Gaston, Oregon Posts: 8092
| offline |
| offline |
[#5] Posted: 04/10/2010 - 09:54:29 AM |  | |
Jim, I have seen them like that and write them up every time.
Have a good day inspecting. Phillip R. Smith Sr. Samantha (Tuscaloosa) AL www.homesweethomeinspectionsal.com "When you inspect crap, you find crap." Phillip 2010 "Always desire to learn something useful." - Sophocles
| offline |
Rochester, New York Posts: 4115
| offline |
[#7] Posted: 04/10/2010 - 1:13:17 PM |  | |
Jim. the NRCA doesn't endorse California valleys for areas with moderate to heavy rainfall. I'm appalled.
Chad Fabry StructureSmart Home Inspection Rochester, NY www.structuresmart.com
Newberg, OR Posts: 2786
| offline |
[#8] Posted: 04/10/2010 - 6:06:21 PM |  | |
I have an issue with Jim's type of repair as well
My concern is that debris will get caught between the new and old pipe jacks. The end result would be water damming up and leaking in at the torn boot. I know it's a far shot, but still. Plus, show me a credible source, besides Jim of course, showing either repair as acceptable.
I'd rather see a new boot pushed down and tarred onto the torn one.
Brandon
Portland Home Inspector |
Severna Park, Maryland Posts: 3462
| offline |
| offline |
[#10] Posted: 04/11/2010 - 04:33:35 AM |  | |
Quote: Originally posted by Brandon WhitmoreI have an issue with Jim's type of repair as well My concern is that debris will get caught between the new and old pipe jacks. The end result would be water damming up and leaking in at the torn boot. I know it's a far shot, but still. Plus, show me a credible source, besides Jim of course, showing either repair as acceptable. I'd rather see a new boot pushed down and tarred onto the torn one.
I hear ya Brandon and I guess it's possible that debris would accumulate between the boots, but I wouldn't call it out for that reason.
I can't show you a credible source that endorses either repair. The NRCA publishes a flat roof repair manual that quite frankly has some pretty wacky repair methods in it. Stuff like mod bit patches with roofing cement smeared along the perimeters. I don't believe they publish a steep sloped repair manual nor have I ever seen one from the shingle manufacturers so I just have to look at something like this and think like water, and I don't see a leak here.
I would avoid letting roof cement and neoprene come in contact with each other. The oils in the cement will breakdown the neoprene.
| Cary |
| offline |
[#11] Posted: 04/11/2010 - 07:13:58 AM |  | |
I look at it like this way. The flashing has a proper way to be installed. It is not installed as it should be.
| offline |
[#12] Posted: 04/11/2010 - 11:17:11 AM |  | |
As it turns out it looks like it is installed correctly, but I don't think it will protect the rip in the base of your flashing Phil. Rain Collar
| Cary |
| offline |
[#13] Posted: 04/11/2010 - 2:55:33 PM |  | |
Cary,
Under their submittal sheet, it is listed as a secondary seal, and not a primary seal. It's debatable, but I would have to argue that it is still an improper "repair".
I would love to see those used over the main boot for UV protection of the primary seals. The primary seals would then last much longer I would think.
Brandon
Georgetown, KY Posts: 2179
| offline |
Melbourne, Victoria Posts: 38
| offline |
[#15] Posted: 04/22/2010 - 4:03:00 PM |  | |
I would avoid letting roof cement and neoprene come in contact with each other. The oils in the cement will breakdown the neoprene. [/quote]
You are 100% right there
| Melbourne Roofing Restorations |
