Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Attics & Insulation >
How hot is too hot?
Previous Topic: Condensation or Urine - Topic - Next Topic: Open VS Closed Cell New Contruction New TopicReply to TopicShare Topic
Posted By
View Profile
Louisville, KY
Currently offline offline
Thread Start First Page
[#1] Posted: 04/14/2010 - 3:18:15 PM
This may sound a bit stupid, but when can you tell when an attic is WAY to hot...or hotter than it "should be?"
I had a home today, 78 outside in the sun. It was 148 in the attic. Doesn't that seem a bit much to you guys? I did notice that the blown in insulation was right up o the ends of the rafters, so I'll be writing lack of ventalation up.
ABI Home Services
Louisville KY Home Inspector
View Profile
Swansea, IL
How hot is too hot?
[#2] Posted: 04/14/2010 - 4:02:07 PM
Sure sounds to damn hot to me. Seems I've read or heard that a properly vent attic should be close to the outside temp.
Mark A. Perry
www.ahis1.com
View Profile
Lafayette, Louisiana
How hot is too hot?
[#3] Posted: 04/14/2010 - 4:16:48 PM
On naturally vented attics, heat is the engine which lifts air to the vent openings at the top, which draws in fresh air at the soffits. If the attic isn't hot, this won't happen.
148 is hot! I recall becoming curious and measuring the temperature of an attic in which I was installing an HVAC duct to a laundry room. It was 141. I couldn't stay in there more than 5 minutes at a time. It took quite a while to do the job.
Marc
View Profile
Evanston, Illinois
How hot is too hot?
[#4] Posted: 04/14/2010 - 4:17:58 PM
I've heard that too Mark.
Cary
Dallas, GA
How hot is too hot?
[#5] Posted: 04/14/2010 - 4:25:36 PM
I get attics that hot all the time.......in August.
I've only seen 125 or so so far this spring.
Tim M.
View Profile
Chicago, IL
How hot is too hot?
[#6] Posted: 04/14/2010 - 4:54:45 PM
I've seen 135 a few times. 148 is really hot.
Kurt in Chicago
View Profile
Collins, NY
How hot is too hot?
[#7] Posted: 04/14/2010 - 6:09:53 PM
Dammit! Now I gotta go put a remote read thermometer in my attic. I know it gets really hot up there, but I've never actually measured it.
Tom
Tom
Dr Joe Lstiburek
View Profile
Dallas, TX
How hot is too hot?
[#8] Posted: 04/14/2010 - 6:18:32 PM
Well ... this past summer (DFW) I had a few attics that were near 160-degrees!!
Did you notice any ventilation baffles to allow air flow from eaves (soffit vents) and into/through attic?
Cheers,
Nolan E. Kienitz
Nolan's Inspections, LLC
Dallas Home Inspections
http://www.NolansInspections.com
Dallas, GA
How hot is too hot?
[#9] Posted: 04/14/2010 - 8:14:59 PM
153 was my highest reading. It was last summer. Direct sun, black shingles, hot humid day.
Tim M.
View Profile
Kenmore, WA
How hot is too hot?
[#10] Posted: 04/15/2010 - 09:33:19 AM
If it was a dark or near black roof, that radiant heat can overcome any natural draft induced by passive ventilation.
Randy Navarro
http://www.thecompleteinspection.com
View Profile
Elizabethtown, PA
How hot is too hot?
[#11] Posted: 04/16/2010 - 5:16:10 PM
In my area, I'd call out 120 degs or more in the attic, unless it was 95 degs outside. If I measured that, I'd expect to see blocked soffits or a problem with the ridge venting or something. I once measured a 145 deg attic.
Matthew Steger
WIN
"Common sense is not so common."
View Profile
Severna Park, Maryland
How hot is too hot?
[#12] Posted: 04/16/2010 - 6:45:29 PM
I suspect that everyone is measuring the temp with IR thermometers.
Keep in mind that when you point it at whatever, you're taking the temp reading of that particular surface. Point it at the sheathing and you can expect to get a high reading since it is getting the radiant heat from the sun plus the build up in the attic space. The temp of that sheathing is not necessarily the temp of the attic air.
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
View Profile
Brandon, MS
How hot is too hot?
[#13] Posted: 04/16/2010 - 10:31:10 PM
140 =/- in the summer
digital thermometer
Charlie Sessums
www.brandonhomeinspector.com
The greatest ideas are often met with violent opposition from mediocre minds.
Albert Einstein
View Profile
Louisville, KY
How hot is too hot?
[#14] Posted: 04/17/2010 - 04:32:07 AM
True. Thats why I took readings on the floor, rafters, insulation, etc... They where all about 3 +/- of each other.
ABI Home Services
Walpole, MA
How hot is too hot?
[#15] Posted: 04/17/2010 - 09:47:43 AM
FTR, I've found around 140 deg F in attics around Boston in summer..
If your car could travel at the speed of light, would your headlights work? (S. Wright-Boston Area Philosopher)
Indianapolis, IN
How hot is too hot?
[#16] Posted: 04/22/2010 - 11:20:22 AM
I have seen where over insulation has blocked attic ventilation. This is dangerous, not only for heat, but for moisture buildup and even release of gases. It is best to have a well ventilated attic and your inspection report should site making improvements in that area.
Sam N
Indianapolis Real Estate Inspector
View Profile
Mesa, Arizona
How hot is too hot?
[#17] Posted: 08/08/2010 - 7:16:30 PM
Talking about HOT!!!
Inspecting Attics in the deserts of Arizona are just that "HOT"
In the summer months of July and August when ambient temps are 110-115 degrees, Attic spaces are always 140-150 degrees.
The attic spaces that have Thermal Shield or Solar Shield on the underside of the decking are much cooler than the normal attic space so that stuff does work as far as keeping the attic space cooler (approx 30-40 degrees difference).
Ricky Wells - Premier Dream Home Inspections
Arizona Home Inspectors
Queen Creek Home Inspectors
Phoenix Home Inspectors
View Profile
Pearland, Texas
How hot is too hot?
[#18] Posted: 08/16/2010 - 1:40:22 PM
I see 125 when it is 90-95 outside here in Houston, with tech sheild that normally drops to about 95-98 degrees.
Robert Welch
ATEX Inspects
http://www.atexinspects.com
View Profile
Kenmore, WA
How hot is too hot?
[#19] Posted: 08/16/2010 - 5:01:10 PM
I didn't do an attic today because of the heat. Just under 140°
Normally, I don't worry about attic heat because I can get in and out pretty fast; however, today's inspection had 12-inches of clearance from the top of the ceiling joists to the underside of the rafters where they were nailed to the ridge board. I normally do those, because I only need 10-inches of clearance to get in; however, it was tight enough to slow me way down and the house was large enough that I probably would have been in there on my belly for 45-minutes; too long in a 140° attic. By the time that I'd gotten in and worked my way the entire length of that space and gotten turned around, I probably would have passed out from heat exhaustion. The thought of being the guy that they talk about the 911 guys rescuing can be a powerful motivation damper.
ONE TEAM - ONE FIGHT!!!
Mike
San Francisco, CA
How hot is too hot?
[#20] Posted: 08/24/2010 - 11:48:32 AM
That does seem really HOT!! We did some spray foam insulation work on my dad's attic and we didn't realize we'd blocked a vent.. So it got miserably hot this summer, way worse than it's ever been! Before he went and bought AC we fixed the vents up and what a difference! If he'd been in Arizona we'd understand but he's up in Washington so we knew straight off that something was up. ;)
It's a bit embarrassing to muck up something like that but at least we solved it before a different inspector saw it.. Oh the irony and humiliation that would have been..
View Profile
Marin County, CA
How hot is too hot?
[#21] Posted: 08/24/2010 - 2:29:35 PM
A home inspector in Las Vegas died on the job in July 2004 in a hot attic. He was a highly qualified, well-trained, and sober person, in good physical shape in his late 30's. The last photo on his camera was the one he took from the attic entrance. It appears that he fainted from the heat when he first stood up inside the attic, fell backwards, and landed on his head on the garage slab. He was alone at the inspection.
The company that employed him holds weekly safety meetings, and after the accident, they changed their policy on attic inspections.
Be careful out there...
Douglas Hansen
Douglas Hansen
www.codecheck.com
View Profile
Lexington, KY
How hot is too hot?
[#22] Posted: 08/24/2010 - 2:44:13 PM
Douglas Hansen
There have been times, especially when negotiating an attic that contains trusses, that I've been dead certain I would pass out, have a stroke, or suffer some other paroxysm before making it back to the scuttlehole. It hasn't happened yet, but you're right. It's silly to take unnecessary risks.
View Profile
Eureka, CA
How hot is too hot?
[#23] Posted: 09/07/2010 - 1:39:15 PM
I backed into a crawl space once. All the vents were insulated over. I turned around and 75% of the area was a swamp. Strange smell. I could see mysef passing out on the back side. Speaking of smelling things I figured they weren't going to pay me either. Supposed to be run thru some kind of Indian welfare deal. I asked for payment before I would write it up. Never happened. At least I didn't die for free.
Denny Waters
View Profile
Boston, Mass.
How hot is too hot?
[#24] Posted: 09/08/2010 - 12:22:41 PM
Last inspection in July. 142F digital --attic in Needham, Ma. Older house--no visible vents in roof.
Jack Ahern Boston on the Charles and Bridgton,Maine
Member ASHI
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
