| Posted By |
.JPG) |
Lakewood, WA Posts: 1478
| offline |
Sagamore Hills, Ohio Posts: 3113
| offline |
Direct vent fireplace hot
[#2] Posted: 06/08/2011 - 1:06:01 PM |  | |
Any heat going out the sidewall vent?
Terry
http://www.hlis.net
This space for let - please inquire within.
.JPG) |
| offline |
[#3] Posted: 06/08/2011 - 1:15:10 PM |  | |
It's vented up though the roof.
Rob Jones South Sound Inspections Seattle Home Inspection
"If you work just for money, you'll never make it, but if you love what you're doing and you always put the customer first, success will be yours." Ray Kroc |
| offline |
[#4] Posted: 06/08/2011 - 1:48:50 PM |  | |
Sorry, read it too quickly.
Were you able to check the roof vent for flow? Able to pull the front to check for obstructions?
Terry
http://www.hlis.net
Kenmore, WA Posts: 15397
| offline |
[#5] Posted: 06/08/2011 - 1:49:12 PM |  | |
Hi Robert,
I'll bet that the opening is slightly lower on it's vertical axis than it's supposed to be. When those things are on, convection pulls a lot of air in at the bottom, heats it and pushes it out across the top of the box. Drop that surround too low in front and all of that heat strikes the back of the top row across the top of the fireplace and heats it.
Tell 'em to use the back of their hand placed against that surround as a means to gauge heat. When they can't comfortably hold their hand there after the fireplace has been on for 15 minutes, they need to reach down underneath and crank the heat back.
ONE TEAM - ONE FIGHT!!!
Mike
.JPG) |
| offline |
[#6] Posted: 06/08/2011 - 2:35:49 PM |  | |
Thanks guys. Terry I was not able to get to the vent exit on the roof.
