Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > HVAC Forum >
Rusted furnace flue
Previous Topic: Boiler Rust - Topic - Next Topic: Chromalox radiant ceiling heat? New TopicReply to TopicShare Topic
Posted By
View Profile
Georgetown, KY
Currently offline offline
Thread Start First Page
[#1] Posted: 01/04/2012 - 09:38:10 AM
What do you tell people when you see the flue rusted like this?
Click to View
45.44?KB
Two story house with the furnace & water heater in garage closets. Both 18 years old.
Induced draft fan at furnace.
Erby Crofutt
B4U Close Home Inspections
Georgetown, KY
www.b4uclose.com
www.kentuckyhomeinspections.com
https://www.facebook.com/B4UCl...pections
Kentucky Home Inspections
Kentucky Home Inspectors
502-570-4054
View Profile
Lexington, KY
Rusted furnace flue
[#2] Posted: 01/04/2012 - 11:36:04 AM
I just tell people what's up, and to keep an eye on the flue pipe. It's likely 18 years old, as well, and the zinc coating has eroded away from the galvanized metal, so it's rusting. It could be fine for several more years . . . or not.
Painting, clearly, is not an acceptable repair method. : )
Click to View
88.15 KB
View Profile
indy, IN
Rusted furnace flue
[#3] Posted: 01/04/2012 - 2:24:54 PM
Click to View
88.15?KB
Are you sure this isn't just camo like on a sub periscope?
View Profile
Crystal Lake, IL
Rusted furnace flue
[#4] Posted: 01/04/2012 - 3:13:29 PM
Click to View
45.44?KB
I always probe them. If they feel solid, I don't mention it.
View Profile
Kenmore, WA
Rusted furnace flue
[#5] Posted: 01/04/2012 - 3:40:18 PM
There's an exhaust gas bouyancy issue.
Single-walled connector in cold space, too many bends in that flue, wrong-sized flue pipe, etc. - something that's causing those gases to cool too quickly, lose bouyancy and stall as they leave the vent. The acidic steam settles around that vent and strips the galvanizing. It also degrades the vent, causes so much mineral salt to form and fall out of the base of the vent that it looks like it's snowing inside the appliance and it can trash the exchanger. If there's an elbow directly below the roof plane, as there often is, there's probably condensate dripping off the elbow onto the insulation.
Or,.......it's just old as hell and wearing out.
When I see those I'll normally walk over to the vent and feel the pipe to see if it's still got a substantial amount of steel left or if it's already paper thin and cracked or about to crack. Often find cracks. Sometimes holes. Sometimes the entire outside of the vent will be eaten away and what you can see from the ground is the liner.
Drive down a city street and look at the condition of those vents and you can identify from the street those houses where furnaces or boilers have an issue with weak exhaust gas bouyancy and could have vent or H.E. issues.
Got a phone call from an HVAC firm a couple of months ago after I'd called a vent after seeing this and checking the vent. Thought he was calling me to argue with me about something. Nah, he was calling to tell me that he was taking the unusual step of calling a home inspector to compliment him for being the first inspector he's ever known that's savvy enough about furnace vent issues to recognize this as an issue.
Told him he should get out more; this is inspector 101 stuff. He disagreed, said it can't be or he'd get called out for it more. Says it's HVAC 101 stuff but the majority of folks in his business don't get it or they ignore it. That explains why I find so many new furnaces with vents that look like that and when I get up on the roof to check them out I find them cracked, holed or ready to fail.
ONE TEAM - ONE FIGHT!!!
Mike
View Profile
Severna Park, Maryland
Rusted furnace flue
[#6] Posted: 01/06/2012 - 9:53:42 PM
I say the following.
The flue pipe is rusting above the roof line. Rusting metal will eventually get holes in it. The holes can allow water intrusion that can damage the buildings materials. Have the rusted flue pipe replaced.
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
Waterbury, Ct
Rusted furnace flue
[#7] Posted: 05/09/2012 - 9:00:46 PM
I am not an inspector but was impressed by the information I found on this site with just a simple google search.
I had a chimney expert come to my home today because I have a "rusting effect" on my shingles and was concerned about resale issues should I choose to move.
The explanation I got was about the condensation of gases and a detailed account of how when you replace a boiler with a more efficient one (I did), your gases aren't as hot and so it is more prone to this issue. When I asked about replacing the flue with another cap, and cleaning up the stain, I was told this would not be possible because the connection to the top would not be the same manufacturing fit, and to clean the shingles would void the warrantee. So, the solution (might) be to relace the entire piping, put a new flue on top.
Is there any other possible solution? I'm looking at a significant expenditure (and construction within my home to remove the old piping) and am out of work.
Please excuse any improper terms - I'm clearly a novice, but could use help and advice.
THANKS!!!
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
