| Posted By |
Oxnard, Ca Posts: 110
| offline |
Gaston, Oregon Posts: 8090
| offline |
Efflorescence Question
[#2] Posted: 02/22/2012 - 08:31:46 AM |  | |
Hydrostatic pressure isn't necessary. I see efflorescence as a result of capillary water movement all the time.
Ashland, VA Posts: 2938
| offline |
[#3] Posted: 04/02/2012 - 7:20:51 PM |  | |
Richmond, VA has a ton of homes ranging between the mid 1800s and early 1900s with plaster walls and ceilings over wood lath. Any time moisture intrudes for a long period of time through plaster, efflorescence is the end result. I can't think of a time I observed it being the result of high humidity. It is typically a roofing/flashing issue or missing mortar in solid masonry walls.
| "This above all: to thine own self be true." - William Shakespeare |
Garland, Texas Posts: 201
| offline |
[#4] Posted: 04/03/2012 - 2:16:35 PM |  | |
elementary explanation water in vapor moves from warm toward cool think cold adult beverage on a warm summer day where is the condensate? outside of the adult beverage container i'd imagine where you're at, warm coastal=moist warm outside, dry cool=air-conditioned inside capillary transfer would deposit and dry on the interior air leakage, absence or breeches in vapor barrier might be the causative source
not nice to install building materials incorrectly, argue with mother nature or try to combat physical laws
Barry Adair trec#4563 http://www.adairinspection.com life is the random lottery of events followed by numerous narrow escapes...accept the good |
