Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
lots of unsealed gaps on siding
Previous Topic: Old Stucco Cracks and No Flashing - Topic - Next Topic: siding identification help New TopicReply to TopicShare Topic
Posted By
 1  2 - Next
cary, nc
Currently offline offline
Thread Start First Page
[#1] Posted: 04/30/2012 - 1:40:31 PM
I just bought my house about one month ago and I am really upset about it now.
First, I always feel like it is vibratating, especially in the kitchen. Everytime I walk through the kitchen, the stuffs on the countertop will vibrate and If I try to push the countertop, It sounds like the whole countertop will vibrate too.
Secondly, there is a really big gap along the whole wall of the garage. Please see the picture below.
Thirdly, there are lot of unsealed gaps between the butt joints of the siding, almost every butt joint. According the report of the inspector, there is no counter flashing visable at joints. However,A weather proof barrier is visible at accessible locations. I am a first home buyer and have no idea how bad it is. So I had an licienced contactor to take a look and he said it is ok and the gap is for expansion and I believed him at that time. However, after I moved in and take a close look at it and found that some gaps are really big and some are even big than 1/8". Please see the picture below.
Is there anything wrong with my house? What should I do? I have no idea. My house is about 6 years old.
Thanks for your patient.
Click to View
46.99 KB
Click to View
55.15 KB
Click to View
33.77 KB
View Profile
Newberg, OR
[#2] Posted: 04/30/2012 - 6:25:18 PM
The siding manufacturer recommends flashing behind the joints, but still doesn't require it. The joints are required to be caulked/ sealed if not flashed. Just get a copy of the manufactuers installation instructions and go from there.
Brandon
Portland Home Inspector
View Profile
Kenmore, WA
[#3] Posted: 04/30/2012 - 8:34:34 PM
Hi,
if it was Color Plus siding it requires flashings at the butt joints, if not, flashigns are preferred but if you don't install them they want to see the butts caulked. Caulking is a lousy choice because the siding will expand and contract heat and cold changes and the caulk invariably fails. Then you daub more caulk on the joint and need to touchup the paint. Before you know it, you've got a thick bead of caulk and paint built up after several re-caulkings and the siding looks like hell.
The vibration; is your floor system truss joists by any chance? If so, the Engineered Wood Association published a paper that tells how to dampen some of the vibration folks experience with TJI's.
ONE TEAM - ONE FIGHT!!!
Mike
View Profile
State: PA & NJ
[#4] Posted: 04/30/2012 - 8:41:04 PM
Have you identified the manufacturer by the pictures?
Which manufacturer doesn't require flashing behind the joints?
Which manufacturer requires caulking if not flashed?
Bill Kibbel, Historic & Commercial Building Inspections - Old House Resources
View Profile
Newberg, OR
[#5] Posted: 04/30/2012 - 10:37:49 PM
Quote: Have you identified the manufacturer by the pictures?
Should be Certainteed or Hardie-- installation instructions are similar. Is there another manufacturer of this stuff that I am not aware of?
Quote: Which manufacturer doesn't require flashing behind the joints?
Certainteed and Hardie....
Quote: Which manufacturer requires caulking if not flashed?
They all require some type of joint treatment, or at least last I checked. If any instructions show otherwise, I'd defer to building code requirements.
I'm too tired to research this stuff right now. The installation instructions keep getting updated/ changed. When Hardie started recommending the use of flashing at butt joints, they stated on their instructions that if flashing was not used, then caulking was required...
I'm not 100% sure who manufactured that siding, but am 99% sure it's one of the 2 manufacturers above. That's why I told the OP to get a copy of the manufactuers installation instructions and didn't just post a set from Certainteed or Hardie.
Bill-- I have a feeling you already know all of this, and are hinting that I should post more specific or precise info. when I do post?? Unfortunately, my current work load doesn't allow for the time to do so.........
Brandon
View Profile
Newberg, OR
[#6] Posted: 04/30/2012 - 10:47:06 PM
Certainteed instructions now specifically state: "DO NOT CAULK" the butt joints, and requires flashing or a joint cover, so my original post was wrong per the most recent set of installation instructions.....
Brandon
View Profile
Chicago, IL
[#7] Posted: 04/30/2012 - 11:23:08 PM
Thanks for the homework; I had one of these yesterday.
Regarding the other stuff, I'm guessing the house is a box, minimally constructed. They're feeling the vibrations from minimally constructed assemblies.
Without a lot of pictures, it's hard to know what's going on.
On the plus side, some form of flashing could be slid under the siding to correct that portion of the issues. It would be a little screwy, but only a little.
Kurt in Chicago
View Profile
Gaston, Oregon
[#8] Posted: 05/01/2012 - 12:25:54 AM
Have you lived in a wood-framed house before? I ask because I've had clients from Asia who are accustomed to concrete or stone construction and have never experienced wood framing before. It's bouncy and creaky and generally feels less solid that concrete or stone. And, as Kurt pointed out, if they used floor trusses or I-Joists, then it's *particularly* bouncy. There are things you can do to address this, but the bounciness itself is not a symptom of a larger problem.
Quote: Secondly, there is a really big gap along the whole wall of the garage. Please see the picture below.
It's no big deal. Fill it with anything.
Quote: Thirdly, there are lot of unsealed gaps between the butt joints of the siding, almost every butt joint. According the report of the inspector, there is no counter flashing visable at joints. However,A weather proof barrier is visible at accessible locations. I am a first home buyer and have no idea how bad it is. So I had an licienced contactor to take a look and he said it is ok and the gap is for expansion and I believed him at that time. However, after I moved in and take a close look at it and found that some gaps are really big and some are even big than 1/8". Please see the picture below.
In your last picture, I see caulk in the joint. It looks like the installer put caulk on the end of one plank and slid the other one up to it, making a caulk sandwich. That's *exactly* what the siding manufacturer specified in 2006 when your house was built. When the caulk fails, as yours has, you were expected to re-caulk it. The new standard, which requires flashing, is a much better solution. It's easy to install the flashing after the fact. Any reasonably intelligent contractor should be able to do this for you.
Quote: Is there anything wrong with my house? What should I do? I have no idea. My house is about 6 years old.
I don't know. But in the pictures you've posted, I don't see anything that's even slightly alarming.
Jim Katen, Oregon
www.amipdx.com
View Profile
Gaston, Oregon
[#9] Posted: 05/01/2012 - 12:29:48 AM
Quote: Originally posted by kurt
. . . On the plus side, some form of flashing could be slid under the siding to correct that portion of the issues. It would be a little screwy, but only a little.
Take a tin shingle, use tin snips to make two little slits 1-1/4" up from each of the lower corners, bend the shingle back ever so slightly above the slits, and slip it up under the siding. The bend corners will hook onto the course below and stay put. With practice, you can do several per minute.
Jim Katen, Oregon
www.amipdx.com
cary, nc
[#10] Posted: 05/01/2012 - 09:22:57 AM
Thanks all for replying. It helps a lot. Since this is my first home, I am really nervouse about it.
cary, nc
[#11] Posted: 05/01/2012 - 09:31:14 AM
Yes. I did live in a wood framed apartment for about five years. I also went to some open houses to feel the bounce. It feels like that my house is a little bit more unstable, especially in the kitchen.
Good to know it. Thanks.
yes, I can see some caulk left there. I never used a contractor before, so what kind of contractor should I use? A general one or any special one?
Thanks.
View Profile
Chicago, IL
[#12] Posted: 05/01/2012 - 12:47:29 PM
Bukiqe. Not to worry too much; it's a house, you can understand it and fix it if necessary.
Kurt in Chicago
View Profile
Seattle, WA
[#13] Posted: 05/01/2012 - 6:14:43 PM
He knows the whole house is tipped over on its side, doesn't he?
Richard Moore
Rest Assured Inspection Services
Seattle, WA
http://www.rainspect.com
View Profile
Gaston, Oregon
[#14] Posted: 05/01/2012 - 6:18:48 PM
. . . It feels like that my house is a little bit more unstable, especially in the kitchen.
Without seeing your house, I can't say for sure. But I think that unstable is probably the wrong word. It sounds like bouncy or springy would better describe the condition. If that's so, it's probably the result of light framing with I-joists.
Quote: . . . I never used a contractor before, so what kind of contractor should I use? A general one or any special one?
The work that you need to have done doesn't require any particular skill, just attention to detail. You want to find someone who's neat and precise. Check out Yelp and Angie's List for recommendations in your area. Try to get referrals from friends or business associates that you know.
Jim Katen, Oregon
www.amipdx.com
View Profile
State: PA & NJ
[#15] Posted: 05/02/2012 - 6:35:30 PM
I asked the questions so I (and anyone else reading the thread) had up-to-date info. I thought that both Hardie and Certainteed now specifically require flashing behind butt joints. When I read your post, I thought maybe that changed.
cary, nc
[#16] Posted: 05/02/2012 - 9:08:17 PM
You are right. Bouncy should be a better word. I googled some solution for my bouncy house and found this:http://blog.luxorcorp.com/2008...-floors/
Is this true? what is the best way to make my floor more solid?
cary, nc
[#17] Posted: 05/02/2012 - 9:12:11 PM
So, I do need to do something with these gaps, right? Flashing is the best way? And how much it will cost? My house is about 3100 square feet.
View Profile
Chicago, IL
[#18] Posted: 05/02/2012 - 9:16:39 PM
Provide a picture of the under side your floor structure from the basement. Several would be good.
Kurt in Chicago
cary, nc
[#19] Posted: 05/02/2012 - 9:39:07 PM
I will do that tomorrow afternoon when my kids take their naps. Thanks a lot.
View Profile
Newberg, OR
[#20] Posted: 05/02/2012 - 10:56:37 PM
Quote: When I read your post, I thought maybe that changed.
Heck, the instructions have probably changed since I looked up the info. and posted what I found. I can't seem to keep up with their installation instructions. Trying to determine what the requirements were at the time of the installation can be even more fun.
Brandon
cary, nc
[#21] Posted: 05/03/2012 - 9:15:19 PM
I can only take some pictures from half the crawl basement. the other half part is too black for me and I am so scared to reach there. My husband is working.
Click to View
50.49 KB
Click to View
32.19 KB
Click to View
52.09 KB
Click to View
64.75 KB Are these enough? Thanks.
View Profile
Chicago, IL
[#22] Posted: 05/03/2012 - 9:57:03 PM
I see some issues with the vapor barrier and the crawlspace vents, but the structure isn't showing me anything that makes me think you've got a major problem.
My guess is what Jim said; you may be used to concrete construction. Wood frame construction feels very different.
Are you from china? I know everything in china is concrete, wood construction is relatively rare.
Someone tell her about vapor barriers and crawlspace venting.
Kurt in Chicago
View Profile
Newberg, OR
[#23] Posted: 05/03/2012 - 10:26:56 PM
Is your issue with venting the fact that it's vented due to that being a humid climate? Other than the possible lack of wire mesh screening, it looks well vented otherwise.
Brandon
View Profile
Kenmore, WA
[#24] Posted: 05/04/2012 - 12:11:55 AM
I'm having a little trouble with the fact the beam runs parallel to the floor joists. Is this such a narrow structure that the floor joists can span the entire crawlspace without overlapping on a beam someplace?
Man, I wish just a third of the crawls I have to go into every year looked half as clean as that one. If they did, I'd be in hog heaven.
Mike
View Profile
Chicago, IL
[#25] Posted: 05/04/2012 - 06:13:15 AM
I saw that, but gave it benefit of the doubt that someone goofed up the beam layout. The long spans are probably the bounce they're feeling.
The craw
Space should have a vapor barrier, close up the vents, and condition the space.
Kurt in Chicago
View Profile
Kenmore, WA
[#26] Posted: 05/04/2012 - 07:40:23 AM
Hi,
It does have a barrier; it's just that it's clear plastic instead of the black type and it's been applied very poorly. If they close the vents without fixing the barrier, the amount of moisture escaping from that soil will become an issue. If they leave the vents open in North Carolina's very humid climate, the amount of humidity that will condense all over everything in that cool crawlspace in mid summer will make it look like it's raining in there. I'm surprised it looks as good as it does for a six year old house.
I'd still like wider shots of the crawl and the layout of that flooring system so I could understand why that beam runs parallel to those joists. The only thing I can think of is that it supports a wall somewhere above and that the joists are able to span that crawl without midspan support. If they span the entire crawl and are at their absolute span limit, or are overspanned, they might be stretched to their limit in which case walking across the floor will be sort of like walking across the head of a drum. I don't see any bridging either. That might be contributing to the vibration, though I've heard for years that research had discounted bridging as being unnecessary.
Xuehong,
Can you get some wider shots of the floor system that show the entire span of the floor? That vapor barrier needs to cover 100% of the soil floor of that crawl. In your climate, it works best if that barrier practically covers the entire interior face of the foundation, the vents are closed and the crawlspace is conditioned. There's a contractor out your way by the name of Jeff Tooley who has written numerous articles on the subject for Fine Homebuilding and the Journal of Light Construction and makes his living fixing crawlspace moisture issues. I'm sure if you google him you can learn much more about how sealing a crawlspace in the humid southeast is better than venting one. Also, visit Advanced Energy Corporation's crawlspace knowledge page; they've done extensive research in your region on crawlspace ventilation issues.
Mike
 1  2 - Next
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
