| Posted By |
Wyckoff, NJ Posts: 433
| offline |
Atlanta, GA Posts: 395
| offline |
PVC drain leg
[#2] Posted: 06/13/2012 - 12:43:54 PM |  | |
Last time I checked the IRC, PVC is not rated for hot water use and is not allowed.
PEX, Copper, CPVC, Steel but not PVC
Bruce Ramsey
Swansea, IL Posts: 1352
| offline |
PVC drain leg
[#3] Posted: 06/13/2012 - 4:51:09 PM |  | |
Around here in some towns you cannot use CPVC on the TPRV extension. Over the winter I renovated a home. 100% new plumbing. All the old cast iron drains were replaced with PVC and the galvanized water lines were replaced with CPVC. On the new water heater I had CPVC on the TPRV extension. When the county came in to inspect they made me replace the extension with metal. It is a real head scratcher, here is a house with ever inch of water line made of CPVC and yet the extension had to be metal.
I suspect part of the reason was so they could charge me for another inspection to come back and confirm it was replaced w/ metal. $50.
Mark A. Perry www.ahis1.com
Crystal Lake, IL Posts: 1174
| offline |
Lafayette, Louisiana Posts: 3861
| online |
Kenmore, WA Posts: 15397
| offline |
PVC drain leg
[#6] Posted: 06/13/2012 - 8:41:37 PM |  | |
There are plastic pipes manufactured specifically to be used as TPR extensions. I think all of the what-if scenarios that deal with this are silly. I bet it performs just as well as metal pipe when/if a TPR activates.
ONE TEAM - ONE FIGHT!!!
Mike
Victoria, British Columbia Posts: 2408
| offline |
Prattsburgh, New York Posts: 216
| offline |
PVC drain leg
[#8] Posted: 06/15/2012 - 5:17:47 PM |  | |
Quote: Originally posted by John KogelQuote: Originally posted by hausdok
Mike
From yesterday's job, tank installed by a plumber. I'd be a fool to call out all the plastic discharge pipes I see, lots of them. Click to View
20.9?KBClick to View
29.39?KB 100 degrees C is 212 F.
...........I agree, however I would say something about the WH laying on its side .............Greg.
