| Posted By |
Swansea, IL Posts: 1359
| offline |
Kenmore, WA Posts: 15412
| offline |
Flickering Lights
[#2] Posted: 08/06/2012 - 09:13:21 AM |  | |
Loose neutral
ONE TEAM - ONE FIGHT!!!
Mike
Springfield, NJ Posts: 1218
| offline |
Flickering Lights
[#3] Posted: 08/06/2012 - 09:49:41 AM |  | |
A few years ago I had the same thing with my house. After a couple of visits from an electrician and bunch of calls to the power company it was finally determined that the transformer (owned by the power company) in front of my house had a problem. They switched it out and have not had an issue since.
Steven C. Hockstein, AIA www.AHMArchitects.com |
| offline |
Flickering Lights
[#4] Posted: 08/06/2012 - 09:55:11 AM |  | |
When I was doing an inspection on a mid century house and I took the cover off the "new" panel front, half the lights in the house went off. Nothing I could find in the panel would cause it, nor correct it. I went outside and lightly banged the meter housing and the lights came back on, but flickered. Corrosion in the meter connections. Give it a try.
Collins, NY Posts: 3164
| offline |
Flickering Lights
[#5] Posted: 08/06/2012 - 10:15:28 AM |  | |
I'll second the meter connections, especially if the new service install didn't include replacing the meter enclosure.
My brother had a similar issue with flickering lights that worsened to include intermittent brown outs on some circuits and eventually lost power to half the house. The back of the enclosure was rusted through and one of the plastic meter lugs was broken. He's very fortunate the arcing didn't burn the place down.
Tom
Walpole, MA Posts: 831
| offline |
Flickering Lights
[#6] Posted: 08/06/2012 - 1:25:34 PM |  | |
Yup.. more in-depth checking of the neutral, meter and hammer that utility a bit more..
Friends of ours lost 'a bunch of stuff ' a few years ago when a transformer decided to go south.... Blinkin' lights are not good..
| If your car could travel at the speed of light, would your headlights work? (S. Wright-Boston Area Philosopher) |
Ridgewood, NJ Posts: 952
| offline |
Flickering Lights
[#7] Posted: 08/06/2012 - 2:05:42 PM |  | |
I had a similar problem with a brand new electric service. The power company came out and installed a recording volt meter. It was determined that the poletop capacitors needed to be replaced. These were located a quarter mile away!
Neal Lewis www.totalhomeinspectionservices.com |
Victoria, British Columbia Posts: 2450
| offline |
Flickering Lights
[#8] Posted: 08/06/2012 - 2:48:26 PM |  | |
Back-stabbed receptacles can cause flickering, but it will always be the same lights. It wouldn't hurt to pull the fixtures that flicker and a few receptacles in a 60-year-old house.
But we are all leaning toward a bigger problem - loose or corroded connections at the service end. I had one side of my service drop to 80 volts one time. The trouble was out on the power pole. Brownouts can destroy electric motors, compressors, etc.
| www.allsafehome.ca |
Spring Hill (Nashville area), Tennessee Posts: 3399
| offline |
Flickering Lights
[#9] Posted: 08/06/2012 - 3:10:05 PM |  | |
Had an owner several years back get mad at me about the flickering lights in his home. His was associated with the washing machine and when he turned it on the house looked like a 1970's disco. It turned out that it was a loose neutral in the panel. Simple fix but the owner was still ticked at me because I did not find it in an empty home with no washing machine, etc, etc..... I must admit that it was one of the funnest things I had seen in a home with almost every light flashing or pulsing as the washer went through it cycles.
Scott Patterson http://www.traceinspections.com
indy, IN Posts: 291
| offline |
Flickering Lights
[#10] Posted: 08/06/2012 - 5:41:13 PM |  | |
I too had a loose connection @ the meter. Half of the circuts would go out, I'd go smack the meter, they'd come back on. The power co switched the meter and no problems since.
Lafayette, Louisiana Posts: 3914
| offline |
Flickering Lights
[#11] Posted: 08/06/2012 - 6:10:00 PM |  | |
Mike nailed it, Mark. Only a crack electrician on-site can find out where. The location-spread of the symptoms suggest the issue would be close to, or within, the main service. Motors could start to burn if it isn't corrected soon.
Marc
| offline |
Flickering Lights
[#12] Posted: 08/07/2012 - 02:38:19 AM |  | |
Thanks All - Once I learn the details of the repair / problem I'll post it.
Mark A. Perry www.ahis1.com
danielsville, Georgia Posts: 18
| offline |
Flickering Lights
[#13] Posted: 08/07/2012 - 10:26:34 AM |  | |
Something that's definitely GWTW is the flicker you will see if you are ever exposed to 25 Hz power and incandescent lights. It's always there, but it only catches your eye from the side every once in awhile. Maybe they could use this on bad guys instead of more intense methods. <bb
| offline |
Flickering Lights
[#14] Posted: 09/04/2012 - 08:50:32 AM |  | |
I followed up on this and it was a loose neutral in the main panel. They said it took 4 complete turns of the lug to tighten it up.
DeWitt, Mi Posts: 3312
| offline |
Flickering Lights
[#15] Posted: 09/04/2012 - 11:01:52 AM |  | |
Hey Mark, don't you hate it when Mike O is right?
Les
