Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Structural Forum >
jointed studs
Previous Topic: Cinder blocks on top of Poured Concrete Wall - Topic - Next Topic: Brick subfloor New TopicReply to TopicShare Topic
Posted By
View Profile
Burleson, Texas
Currently offline offline
Thread Start First Page
[#1] Posted: 02/18/2005 - 8:03:57 PM
Hey guys I was looking at some new construction in my area (being nosy!) and I saw a 2-story home going up. Every stick of wood in this place was jointed. I thought that was a no-no for load bearing walls especially in a two-story. Any thoughts.
Thanks
Buster
Buster
Burleson, Texas
View Profile
Columbus, Mississippi
jointed studs
[#2] Posted: 02/18/2005 - 10:46:52 PM
Well I don't much in the IRC, but "wall construction" is a big section. I did find R602.1.1 End-jointed lumber, which says "Approved end-jointed lumber identified by a grade mark conforming to R602.1 may be used interchangeably with solid-sawn members of the same species and grade." It's not dead-on point or crystal clear, but it sounds like anything else isn't "approved".
Then there's the old fall-back rule about drilling and notching (can't exceed 25% of the width), but it seems more of a stretch to me.
Then there's also common sense. Lots of spliced load-bearing studs is plain ole' stupid. The builder must be some cheap-skate.
Brian G.
Cheap, But Not That Cheap
View Profile
Conroe, Texas
jointed studs
[#3] Posted: 02/19/2005 - 06:21:13 AM
Buster, if you're talking about finger jointed (end jointed) lumber, then it's allowed. Test have shown those boards break in the wood and not the joints.
They are also generally straighter.
The trick is, your 2x4 finger jointed stud can not be used in horizontal applications such as top plates, collar ties, etc. If you read the grade mark on 'em, they'll say for vertical stud use only.
I think these are what you're talking about.
Donald Lawson
www.best2inspect.com
Houston Texas
What they truly don't understand is the principle so eloquently stated by Abraham Lincoln: "You cannot strengthen the weak by weakening the strong. You cannot help the wage-earner by pulling down the wage-payer. You cannot help the poor by destroying the rich. You cannot help men permanently by doing for them what they could and should do for themselves."
View Profile
Anthem, AZ
jointed studs
[#4] Posted: 02/19/2005 - 11:22:53 AM
Donald is correct! Vertcial application only.
Chris Prickett
REAL Truth in Real Estate
(623) 297 2557
www.goprickett.com
http://tiny.cc/prickettblog
View Profile
Burleson, Texas
jointed studs
[#5] Posted: 02/19/2005 - 1:27:33 PM
Yeah Donald I was looking at finger jointed studs. I really didn't pay attention to the top plates but I think I'll run by again and look.
This was a tract home going up in a local subdivision. I think Optima is the builder. I don't know if they are a local, regional or national builder. The finished products look okay but I was curious about the stuff you can't see after the sheetrock goes up.
I haven't done any phase inspections on new construction yet but I want to so I thought I would start visiting some sites under construction and practice. I have done a couple of final inspections and one for end of warranty.
Thanks
Buster
Buster
Burleson, Texas
View Profile
Chicago, IL
jointed studs
[#6] Posted: 02/20/2005 - 5:07:18 PM
The glue joint is substantially stronger than the wood.
Kurt in Chicago
View Profile
jointed studs
[#7] Posted: 02/20/2005 - 5:22:02 PM
Ah-so. I'm thinking spliced, not finger-jointed...my bad!
They're straighter than regular studs? How come that doesn't hold for finger-jointed moulding? Ever look down some of that stuff?
Brian G.
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
