Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Structural Forum >
Cinder blocks on top of Poured Concrete Wall
Previous Topic: Structural header bearing info - Topic - Next Topic: jointed studs New TopicReply to TopicShare Topic
Posted By
Gaithersburg, MD
Currently offline offline
Thread Start First Page
[#1] Posted: 02/27/2005 - 10:34:21 AM
Does anyone know the reason behind placing two rows of cinder blocks on top of a poured concrete basement foundation? This is a row town house that was built in 1976.
Thanks,
Kevin
Kevin A. Richardson
MD Licensed Inspector #29727
View Profile
Chicago, IL
[#2] Posted: 02/27/2005 - 10:42:34 AM
If there is no immediate or apparent structural purpose, my guess is that the builder/foundation guy blew it on the site elevation. I've been on more than a couple jobs where someone simply didn't get the elevation right, & the builder had to "shim" it up w/some block.
Kurt in Chicago
View Profile
Orient, Ohio
[#3] Posted: 02/27/2005 - 7:20:48 PM
I have seen a couple of foundations where the concrete forms used didn't provide the needed headroom. Perhaps they were planning on a dropped ceiling. Instead of getting higher forms the builders had the walls raised with masonry. The block masonry is weaker and the different expansion rate causes cracks. If I had to do it I would have vertical reinforcing to connect the block to the concrete.
But it could be that the builder messed up the elevation.
David A. Inspecting Columbus, Ohio
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
