Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Foundation Systems Forum >
Basement Floor Heaving
Previous Topic: 40 foot long horizontal crack - Topic - Next Topic: Marks on basement walls - cause??? New TopicReply to TopicShare Topic
Posted By
View Profile
Sagamore Hills, Ohio
Currently offline offline
Thread Start First Page
[#1] Posted: 05/07/2005 - 08:19:10 AM
Hello All:
On a few of the older homes that I have inspected the basement floor (concrete) has pushed up. When you knock on it it's as hollow as a drum.
I would guesstimate that this is due to freeze/frost conditions pushing the floor up however, I would have thought the floor was below the frost line. Also, wouldn't you need an active source of water to lift the floor. Some areas are pushed up a foot or more.
Comments?
Thanks...
Download Attachment: basement1.jpg
39.47 KB
Download Attachment: basement2.jpg
46.88 KB
Terry
http://www.hlis.net
This space for let - please inquire within.
View Profile
State: PA & NJ
[#2] Posted: 05/07/2005 - 10:05:42 AM
I see this condition almost daily. Typically, a very thin layer of concrete was added later only as a soil covering. No gravel, vapor barrier or reinforcing mesh is present. As the concrete cracks and settles over soft soil, the other edge lifts. There is sometimes soil erosion from water movement and heaving as water rises under the concrete.
It can also be a result of failed waste lines washing out soil under the slab. Looking at the second photo, showing pretty ancient cast waste lines penetrating the floor, I would suspect this may be a probable cause.
Bill Kibbel, Historic & Commercial Building Inspections - Old House Resources
View Profile
[#3] Posted: 05/07/2005 - 10:30:44 AM
Hi Bill & thanks for the reply.
If the waste line were leaking wouldn't his cause a sink hole effect due to soil errosion?
This is just like someone put a balloon under the floor, a big bubble.
Terry
http://www.hlis.net
View Profile
Chicago, IL
[#4] Posted: 05/07/2005 - 12:59:49 PM
I see it daily also. City infrastructure backups can cause the old clay tiles to leak & flood the subgrade soil under the concrete. Bill described old concrete floors perfectly; it is usually just a skim of weird flinty mud over the dirt. When you flood the area, it bubbles up.
Old city sewers back up, clay tile bell & hub joints leak, & floors buckle. I always tell folks to videoscope the sewer to determine it's condition.
Kurt in Chicago
View Profile
Greensburg, PA
[#5] Posted: 05/13/2005 - 2:12:53 PM
Terence,
There is another possibility. High water table intermittently. The water pressure cracks to concrete (stains), then goes back down and compacts the soil underneath causing the hollow sound. This is one of the rare cases where I recommend interior drains and a sump pump. The entire floor may need to be removed and replaced but after the drainage is added.
Bruce
Walpole, MA
[#6] Posted: 05/14/2005 - 05:11:38 AM
I see this in 2 Boston Harbor-area seaside communities in a particular set of neighborhoods. Clay soils that expanded due to getting wet (after being dry). Major humping of floors, actually causing posts to rise/beams etc. Some of these houses look like fairy-tale tippy houses.
If your car could travel at the speed of light, would your headlights work? (S. Wright-Boston Area Philosopher)
View Profile
Kenmore, WA
[#7] Posted: 05/14/2005 - 06:47:25 AM
Hi All,
Rob, that's what I thought too when I first read the query. What's the soil composition there? Any bentonite?
I've never seen one, but I've been told that in some parts of Colorado, where there is a lot of betionite, houses with basements there have crawlspaces beneath their basement floors to allow for seasonal movement of bentonite that would otherwise cause basement floors to heave without them.
ONE TEAM - ONE FIGHT!!!
Mike
Walpole, MA
[#8] Posted: 05/15/2005 - 03:08:44 AM
Mike: I don't know the soil comp but it is some type of clay I'm sure. The areas are near the mouths of inland river systems that dump into Boston Harbor. Both North and South of Boston ("South Showah and Nawth Showah"). I even saw it raise an under-building parking area (asphalt) so that the under-area looks like an upholstered pillow in areas. That building is modern-vintage on pilings (to bedrock)and had no problems otherwise.
If you like soil issues and buildings, check out:
www.bostonwaterconservancy.org
Those buildings in Boston's "Back Bay" are also regularly inspected by Boston-area inspectors like myself. It helps to be knowledgeable about the history of Boston and the landfill history when you inspect in those areas.
View Profile
Springfield, NJ
[#9] Posted: 05/15/2005 - 06:55:37 AM
A few years ago I had the potential of designing some buildings in Colorado and I started to investigate Expanding soils. I found this site and learned a lot:
http://www.usace.army.mil/inet...5-818-7/
Walpole, MA
[#10] Posted: 05/16/2005 - 02:31:51 AM
I made an error in a previous post.
Try:
www.bostongroundwater.org
to learn about Back Bay water table issues.
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
