| Posted By |
 New Member
Machias, ME Posts: 20
| offline |
Thread Start First Page [#1] Posted: Dec 05 2005 - 7:49:41 PM |  | |
Hi All,
Situation: Bathroom vent terminates in a poorly ventilated attic in a small one story home. The home owners complain of heavy condensation on all windows and on the chimney that is exposed all the way down. One bedroom has persistent mildew spots on the interior walls. None of these spots appear anywhere else in the home. I am certain that the condensation is a result of high relative humidity indoors.
Question: Why does the mildew just appear in this one room? It is the only room painted ALL black, could it be something in the paint?
Download Attachment: Image Unavailable! Sorry you must be logged in to view images. Click Here For Free Registration 45.26 KB
Download Attachment: Image Unavailable! Sorry you must be logged in to view images. Click Here For Free Registration 35.32 KB
Thanks,
Eric Machias, ME www.holminspections.com |
 Editor - TIJ
Kenmore, WA Posts: 12154
| online |
Moisture in attic
[#2] Posted: Dec 05 2005 - 8:15:35 PM |  | |
Hi,
Is it the room where adults sleep? Adults pump a lot of moisture into the air at night. If the rooms of that wall are poorly insulated, you'd be getting condensation on them wherever nailheads cool the surface or there are air leaks. That condensation will feed the mildew.
Get that attic vented to the exterior, get a good ground cover on the soil beneath the home if there is a crawlspace and ventilate the home better.
ONE TEAM - ONE FIGHT!!!
Mike
 New Member
| offline |
Moisture in attic
[#3] Posted: Dec 06 2005 - 9:09:55 PM |  | |
Thanks for your input Mike
Only the daughter sleeps in that room, but they did mention that the door is nearly always closed. The mildew spots are random, i.e. not on nail heads. The parents' room is right next to that room and the walls show no growth (high moisture with heavy condensation on the windows though). There were dozens of candles in the daughter's room and she seemed like the type to sit in there and burn them in her black room with gothic jewelry hanging all over the place. She did complain of headaches once the *mold* appeared (of course) but maybe she is just asphyxiating herself.
I did explain to them the importance of getting the bathroom fan vented outdoors and improving the attic ventilation. I did not mention any of my thoughts about the young lady though!
Thanks again,
 Member
West Bend, Wisconsin Posts: 189
| offline |
Moisture in attic
[#4] Posted: Dec 07 2005 - 05:51:38 AM |  | |
Hi Eric, Just some otherthings I have run into for these problems.
1. Window treatments - blinds, curtains, shades this restricts the warm are from getting to the window pain making the surface colder and thus more apt to have condensation.
2. Heat Register Either not loacted under window or being blocked by furniture or restriced by damper.
3. Window direction Window may have northerly facing making the glass a bit cooler the the other
Houses are very dynamic and these problems rarely are a simple one hit solution although I have seen something as simple as a teddy bear against an exterior wall insulate the heat away from the wall which led to mold growth on the wall behind the bear.
Carl West Bend, WI
Carl Eisen Appletree Home Inspections LLC www.appletreeinspections.com
"When you come to a fork in the road, take it." - Yogi Berra
Active Member
lawrenceville, georgia Posts: 354
| offline |
Active Member
Walpole, MA Posts: 390
| offline |
Moisture in attic
[#6] Posted: Dec 07 2005 - 2:38:37 PM |  | |
Contact Stephen King...he'll figure out the black-room/Gothic-kid/mold spots issues. He can drive over...
 New Member
| offline |
Moisture in attic
[#7] Posted: Dec 07 2005 - 6:30:37 PM |  | |
Paul,
I take your point. I made that comment tongue in cheek but I think you have a valid point there. Maybe she IS lighting all those candles at once. I guess I am naive about those things, it just seems so preposterous.
Thanks,
