Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Plumbing Forum >
FR light on water heater??
Previous Topic: toilet age - Topic - Next Topic: There, its fixed! New TopicReply to TopicShare Topic
Posted By
Minot, ND
Currently offline offline
Thread Start First Page
[#1] Posted: 07/19/2009 - 8:19:23 PM
Does anyone know what this red light that was blinking on this Richmond water heater is for? It says FR below the red light... Its a 2004 water heater with a powered exhuast.
Thanks
Download Attachment: jodi cam 252.jpg
215.87 KB
Jodi
View Profile
Montreal, Quebec
[#2] Posted: 07/19/2009 - 8:34:56 PM
I would assume with my limited knowledge ''FR'' means ''Flame Rod'' - Either indicating defective, or needs attention (servicing).
See link for manual - As per Fig. 12on pg. 12 defective flame rod would notlet burner go on and hence heat water.
Was the water heater operating properly?
Probably needs a new flame rod.
http://www.gsw-wh.com/pdfs/pro...7-1B.pdf
Joe Laurieri
joe@abitatinspect.ca
www.abtatinspect.ca
Minot, ND
[#3] Posted: 07/19/2009 - 8:36:46 PM
Yes it fired up just fine when I used the thermostat on the unit...
Jodi
View Profile
Montreal, Quebec
[#4] Posted: 07/19/2009 - 8:38:37 PM
From page 13 of said manual:
"If a flame cannot be established within the trial for ignition period, the control will stop the flow of gas.
The control will continue to energize the blower (interpurge) and attempt ignition again. If a flame
cannot be established after three attempts, thecontrol will lock-out. A red LED light on the control
will flash continually indicating a lock-out condition occured. Unplugging the 120VAC power supply to
the water heater then restoring power will reset the control.
NOTE: The control will perform a self-diagnostic check upon start-up and the LED will flash 3-4 times.
During normal operation the LED remains off. A solid red LED indicates that the control must be replaced."
As we say in Quebec - Voila !!!!!
Joe Laurieri
www.abtatinspect.ca
View Profile
Kenmore, WA
[#5] Posted: 07/19/2009 - 8:46:53 PM
Jeez Jodi,
It's all right there on the label to the right of the temp control dial. Just read the flash sequence and compare it to the label and you'll know whether it's normal or something needs to be done to correct it.
ONE TEAM - ONE FIGHT!!!
Mike
Minot, ND
[#6] Posted: 07/19/2009 - 9:00:21 PM
Jeez Mike.... I missed that ... Never seen a control setup like this one. Thank you for pointing it out!
Jodi
Minot, ND
[#7] Posted: 10/09/2009 - 5:28:32 PM
Those are very rare
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
