| Posted By |
Frankfort, Indiana Posts: 194
| offline |
Chicago, IL Posts: 9507
| online |
Weather Resistant Barriers
[#2] Posted: 10/28/2009 - 11:27:56 AM |  | |
Most mfg's. want to see a membrane pan under the window with an interior dam, and drip caps or other flashing over the window, similar to (or the same as) under an exterior door.
The pan should extend out over whatever sheathing is applied, so I figure that must include foam board.
Kurt in Chicago
| offline |
| offline |
[#4] Posted: 10/28/2009 - 12:59:27 PM |  | |
Here is a photo of a through wall penetration that is not flashed or sealed to the exterior sheathing. What really has me intrigued about this is there was a dark spot on the floor below the clothes dryer that started at the band board and went inward. The spot tested about slightly wetter than the surrounding sub-floor materials.
The homeowners, for whom I am working, indicated that the washer has never overflowed, and the stain is adjacent to the washer, not below it. What I am speculating is happening is moisture is penetrating the masonry veneer, running down the back side of the veneer or the sheathing, following the dryer vent into the wall cavity, then sinking to the sub-floor.
Given the visible penetration of the HVAC exhaust it appears that exterior wall penetrations were not sealed to the water resistant sheeting. Also if you look at the photo you can see where water has made its way in at the HVAC exhaust.
Bryan
Click to View
 53.05 KB
| Bryan |
Newberg, OR Posts: 2786
| offline |
| offline |
[#6] Posted: 10/28/2009 - 1:08:31 PM |  | |
Quote: Originally posted by Brandon WhitmoreQuote: Very true. Let me phase it a different way. How do you flash the head of a window or door when there is nothing to lap over the head flashing? The same would go for a pipe penetration. I have no idea what the manufacturers require, but I would let in flashing above windows, etc. With pipe penetrations, I would make sure that there is a trim block at all penetrations and let in flashing there as well.
When you say "let in" are you referring to extending the flashing to the interior side of the sheathing? Cause that is the only way I see to keep the water out of the wall assembly.
Bryan
| Bryan |
Collins, NY Posts: 3143
| offline |
[#7] Posted: 10/28/2009 - 1:17:55 PM |  | |
Or you could simply install a WRB and conventional flashings. Sometimes progress isn't really progress.
Tom
Tom
| offline |
| offline |
[#9] Posted: 10/28/2009 - 2:28:40 PM |  | |
Quote: Originally posted by Brandon WhitmoreQuote: When you say "let in" are you referring to extending the flashing to the interior side of the sheathing? I'm surprised that they are using sheathing on all of the walls. In this area, if they build with something like Dow foam board, they don't have sheathing behind it.
I may have miss used the sheathing term for there is no structural panels on the exterior of the house, only foam board.
Bryan
| Bryan |
| online |
[#10] Posted: 10/28/2009 - 3:16:19 PM |  | |
Maybe I missed it, but what's the cladding? They can't be using foam panels for the cladding.
Kurt in Chicago
| offline |
| online |
[#12] Posted: 10/28/2009 - 6:29:10 PM |  | |
Well, if it's at the brick, there should be full through wall flashing above and below the windows with end dams, weeps, and wicks, with the flashing lapped out over the foam.
If it's at the siding, the pan flashing should be detailed into the WRB and over the foam, w/a drip cap over the window detailed via shingling into the WRB.
I think that's it, but unless I saw a better picture, I'm not absolutely sure what the correct method would be.
Kurt in Chicago
| offline |
[#13] Posted: 10/28/2009 - 7:07:49 PM |  | |
| Quote: Originally posted by kurt
That is where I am having the challenge. How does one install flashing for a window, door, or other penetration in a shingle fashion when the sheathing is your WRB? The only way I can see it being done is to cut through the foam board and install a "Z" type flashing to cap off the flashing detail. Currently around here builders are relying on self adhering flashing tapes to do the job; however, my personal opinion is the tape will fail much sooner than later especially on the horizontal details.
Bryan
| Bryan |
Kenmore, WA Posts: 15394
| offline |
[#14] Posted: 10/28/2009 - 9:05:06 PM |  | |
I'd say that the head flashings and Z-flashings flashings and windows need to be installed to the rough framing first and then the sheating installed.
ONE TEAM - ONE FIGHT!!!
Mike
Brandon, MS Posts: 951
| offline |
[#15] Posted: 10/28/2009 - 9:23:48 PM |  | |
That is where I am having the challenge. How does one install flashing for a window, door, or other penetration in a shingle fashion when the sheathing is your WRB? The only way I can see it being done is to cut through the foam board and install a "Z" type flashing to cap off the flashing detail. Currently around here builders are relying on self adhering flashing tapes to do the job; however, my personal opinion is the tape will fail much sooner than later especially on the horizontal details. Bryan
What ever could you mean?
Click to View
 57.64 KB
Charlie Sessums www.brandonhomeinspector.com The greatest ideas are often met with violent opposition from mediocre minds. Albert Einstein
| offline |
| online |
[#17] Posted: 10/29/2009 - 04:07:06 AM |  | |
I've never seen it either.
Why wouldn't one detail the flashing into the foam board in the same manner as they would any other WRB? It's thicker, but it's still the WRB, right?
It would mean Z flashing instead of tape, and I'd probably want a good sheet metal guy on site to customize channel in whatever profile was necessary.
Kurt in Chicago
| offline |
[#18] Posted: 10/29/2009 - 05:25:36 AM |  | |
Tape was never intended to replace flashing details, it was meant to be used in addition to proper flashing. Another best practice thing that is misused and misunderstood. I don't see any problems with structural foam sheathing, but there still needs to be a WRB and proper flashing systems. They're inter-dependant not inter-changable.
Tom
Tom
| online |
[#19] Posted: 10/29/2009 - 07:32:42 AM |  | |
No one said they were.
Tape is the required means for sealing WRB, i.e., Tyvek, in all sorts of applications. Tape is good when used as designed.
Peel and stick is just fine for door pans, if one knows how to install peel and stick door pans. Sure, I have my guy solder up copper pans for some jobs, but some jobs can't afford copper pans. For all practical and useful purpose, peel and stick is tape and flashing, no?
If I'm reading the mfg's. stuff correctly, the SIS can be the WRB. It doesn't say you have to use housewrap over the SIS (clearly stated as "optional"), and they also indicate you have to tape the seams with Weathermate, the same stuff that goes on housewrap. Meaning, tape is part of the WRB, therefore it has to be detailed into flashing.
So, I'm not sure your statement is correct.
Kurt in Chicago
| offline |
[#20] Posted: 10/29/2009 - 07:58:51 AM |  | |
If the foam is intended to be the WRB then why does Dow manufacture a house wrap? This is no different than any other discussion about the differences between minimum standards and best practice. When there are builders out there that still think that nailing flanges are adequate flashings, a sheathing material that functions as a WRB is an invitation to disaster. If I were going to build new I'd be looking at advanced framing and SIS, but ther would be appropriate flashings and a WRB in the wall system too. Far less costly than detailing windows and doors to the back side of the sheathing, which is a concept that will escape the grasp of most builders out there.
Tom
Tom
| offline |
[#21] Posted: 10/29/2009 - 08:19:52 AM |  | |
I think the real challenge is keeping the flashing properly shingled into and behind the WRB when utilizing foam board. Yes the easiest way would be to do a layer of house wrap on the exterior; however, it is additional cost and we all know that will not happen.
I also found this detail on BSC web site. It shows utilizing "tape" to seal the flashing to the foam board. In my opinion this still creates a reverse shingle flashing application that will fail over time.
Bryan
Download Attachment: WindowFlashingdetail.doc 83.38 KB
| Bryan |
| offline |
[#22] Posted: 10/29/2009 - 08:40:56 AM |  | |
Quote: Originally posted by BryanI think the real challenge is keeping the flashing properly shingled into and behind the WRB when utilizing foam board. Yes the easiest way would be to do a layer of house wrap on the exterior; however, it is additional cost and we all know that will not happen. I also found this detail on BSC web site. It shows utilizing "tape" to seal the flashing to the foam board. In my opinion this still creates a reverse shingle flashing application that will fail over time. Bryan Download Attachment: WindowFlashingdetail.doc83.38 KB I guess you didn't read what I'd posted very carefully; Joe Lstiburek is endorsing this method and has tested it.
Going up against an opinion of Dr. Joe's is a pretty risky thing to do in my opinion. They guy lives and breathes for building envelope challenges.
Mike
| offline |
[#23] Posted: 10/29/2009 - 08:49:51 AM |  | |
I know I read what you posted and have looked at his web site and know his passion about building envelopes. It just appears to be backward to me.
Bryan
| Bryan |
| offline |
[#24] Posted: 10/29/2009 - 09:01:05 AM |  | |
oooooooo'kay
OT - OF!!!
M.
| online |
[#25] Posted: 10/30/2009 - 06:17:02 AM |  | |
I think this is a perfect example of resistance to new engineered methods of building. In this case, it's us HI's, not the builders.
Personally, I think it's brilliant, and it's the future.
I've never seen it, and look forward to the time when I do.
Kurt in Chicago
