Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
Blackish substance on siding
Previous Topic: Row Lock flashing - Topic - Next Topic: Wire Loops and circular plugs in brick veneer New TopicReply to TopicShare Topic
Posted By
Everett, WA
Currently offline offline
Thread Start First Page
[#1] Posted: 12/09/2009 - 11:19:38 PM
Today found me at a 1912 home. I noticed a black/reddish substance on the north side of the home. Some spots looked as if they came straight through the wood siding, other stains appeared to run down the face of the siding and onto the wood trim of the windows below.
Just to the right of this window is a shower/bath that has been recently installed. Several pieces of new siding were installed on the top 1/3rd of the home at this location and the home was recently painted. The home has been vacant for approx. 6 months. Renters before that.
The friendly neighbor...gotta love 'em...said that the discoloration was much, much worse prior to the new paint job, and now this substance was bleeding through again, and no one has been living in the home to use the shower.
The window frame and sill plate below this location in the basement contained wood rot and carpenter ant damage. There has clearly been a leak in the shower/tub prior to the repairs and I'm sure water entered this wall, creating the need for repairs.
My question is, what is this stuff? I'm assuming some type of asphalt building paper behind the siding, but why would it continue to bleed through?
Any ideas would be great.
Click to View
27.6 KB
Click to View
24.02 KB
Click to View
43.06 KB
Rob Renfro
CHI
View Profile
Kenmore, WA
[#2] Posted: 12/09/2009 - 11:49:57 PM
If the place has been re-sided and they used roofing felt behind the siding versus building paper, there may be petroleum distillates bleading out of the felt onto the siding.
OT - OF!!!
M.
Walpole, MA
[#3] Posted: 12/10/2009 - 02:11:48 AM
Looks like 'tannin' staining from ice-dam leaks to me...
If your car could travel at the speed of light, would your headlights work? (S. Wright-Boston Area Philosopher)
View Profile
Sagamore Hills, Ohio
[#4] Posted: 12/10/2009 - 03:24:04 AM
The mulch that the neighbor was referring to is artillery mulch but that doesn't look like it. Artillery mulch leaves little black dots.
Does look like mold however, did you checked these areas with the pins?
Terry
http://www.hlis.net
This space for let - please inquire within.
View Profile
Ashland, VA
[#5] Posted: 12/10/2009 - 03:35:41 AM
One has to wonnder if the leak has not been fully addressed.
Or, could it really be an insulation issue, as in the lack there of behind the shower causing some wicked condensation.
Just a couple of thoughts...
"This above all: to thine own self be true." - William Shakespeare
View Profile
Collins, NY
[#6] Posted: 12/10/2009 - 05:18:09 AM
Around here a house that old usually has a rosin paper WRB if it has any at all. If they used asphalt impregnated felt under the new siding above, any moisture in the wall will be driven out through the more permiable older areas of the wall. That kind of tannin stain is the result. I would wager that there is/was wet wood in the wall well up into where they new siding is.
Tom
Tom
Dr Joe Lstiburek
Everett, WA
[#7] Posted: 12/10/2009 - 07:54:39 AM
There was a leak for sure sometime in the past as indicated by the damaged/stained subfloor in the basement and the destroyed frame and sill around the window beneath.
I did test for moisture, however the home has been vacant for 6 months so I was told. As far as residing, portions were resided, but most of the new siding was above these stains. The neighbor also mentioned that the stains were there a long time and much worse prior to any repairs.
That's what has me puzzled.
- Orinally really bad stains
- Repairs made to bathroom (new tiled surround)
- Fresh paint at exterior
- Vacant for 6 months (no one using shower)
Maybe residual moisture in wall cavity is pushing resin/asphalt through siding?
I'll just report what I see on this one.
Thanks!
Rob Renfro
CHI
NY, NY
[#8] Posted: 12/10/2009 - 2:18:17 PM
In all the accounts listed above by you and other members, all seem like valid possiblities.
Sometimes I feel like our curiosity gets us to investigate further than we need to.
I personally would have used a moisture meter just to see if it was wetter than areas around it. Checked the eave and roof closely in this area, then written up that further investigation is needed.
If the sub structure was still wet when they made the repairs, and no one has lived in the home since, I could be condensation from a greenhouse effect of the house being sealed up and is now sweating. The damage before that could have been from the actual leak. but if moisture was sealed in, that could lead to sub structure rot. We can't do distructive testing to find out if that is the case but it should definately be looked into further.
View Profile
Rochester, New York
[#9] Posted: 12/10/2009 - 3:08:04 PM
It looks like a situation where the bath tub (now tub /shower) is against the exterior wall and the tub enclosure or window penetration is leaking into the wall cavity
Chad Fabry
StructureSmart Home Inspection Rochester, NY
www.structuresmart.com
View Profile
[#10] Posted: 12/10/2009 - 3:12:55 PM
Well said that man.
Terry
http://www.hlis.net
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
