Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
 All Forums
 Technical Forums
 Tools & Equipment
 Voltage drops reading on the suretest
Errors and Omissions Insurance for home inspectors, appraisers, agents, brokers and other real estate professionals.
Previous Topic: Bought Another Fenix - Topic - Next Topic: Fluke 62 New TopicReply to TopicShare Topic Printer FriendlyBookmark this Topic
Posted By
West Jordan, Utah
Currently offline offline
Thread Start First Page
[#1] Posted: Feb 01 2010 - 6:12:55 PM
I get voltage drop readings on the suretest over 5% all the time but when I check the volts from the panel and at the outlet I see 120 aprx. should I ignore the voltage drop reading?
God bless us one and all!
View Profile
Editor - TIJ
Kenmore, WA
Currently online online
[#2] Posted: Feb 01 2010 - 6:21:03 PM
The acceptable range for voltage is 108 to 132 volts. They used to say that a 10% drop was unacceptable. 108 is a 12 volt drop from 120 volts or 10%, no? I guess that's where they came up with the 108 volts.
Anyway, I've mellowed over the years. I think I'd only report it if it was in excess of 10% and reading less than 108 volts. I don't think you're going to see that with new wiring but you might see it with K & T or some of the older post-WWII stuff.
ONE TEAM - ONE FIGHT!!!
Mike
View Profile
Senior Member
[#3] Posted: Feb 02 2010 - 06:50:15 AM
That is one of the problems (not really a problem, but just too much information) with a ShureTest tester. I use to report voltage drops, but I got so tired of electricians saying that they could not really do anyting about it because it was an issue with the utility company. Then everyone would look at me for an answer.
I stopped looking voltage drops many years back.
Scott Patterson
View Profile
Associate Editor - TIJ
Charlestown, Massachusetts
[#4] Posted: Feb 02 2010 - 07:37:14 AM
You should do a search of these forums for that info, because it has been discussed at length in the past. Jim Katen had a nice treatise on the subject as I recall.
Jim
www.AlMorrison.com
www.CasasDelMarPV.com
View Profile
Active Member
Louisville, KY
[#5] Posted: Feb 04 2010 - 09:59:48 AM
I had a bathroom the other day with 12.8vd @20amp. The house had many other eletrical issues as well, no grounds on half of the plugs, doubletaps, ect.... Time to call old Sparky!
ABI Home Services
Louisville Home Inspections
Louisville Home Inspectors
View Profile
Senior Member
Lafayette, Louisiana
[#6] Posted: Feb 04 2010 - 10:14:32 AM
Quote: That is one of the problems (not really a problem, but just too much information) with a ShureTest tester. I use to report voltage drops, but I got so tired of electricians saying that they could not really do anyting about it because it was an issue with the utility company. Then everyone would look at me for an answer.
A while back, there was a thread about feeding sub-panels from other sub-panels. That's one type of wiring practice that can result in voltage drop issues because the impedances add up. But the utility? Not a chance. Need another electrician. If you still think it's the utility, check the voltage drop on an outlet that is very near, or attached to the main panelboard.
I've never bothered with checking voltage drops but my eye is always on the lookout for light bulbs that suddenly dim for a few seconds. When I see it, the focus of the inspection is adjusted a little closer towards the electrical installation.
Marc
Member
Denver, CO
[#7] Posted: Feb 05 2010 - 07:37:22 AM
Chances are good that Sparky won't have a clue. The voltage drop provisions are an unenforceable "fine print note" in the NEC. I used to routinely measure voltage drops of 10-20% before my Suretest got stolen.
My advice is to throw away your Suretest.
View Profile
Active Member
Louisville, KY
[#8] Posted: Feb 05 2010 - 10:37:02 AM
I was referring to the rest of the issue's not the VD. Besides, wouldn't selling it be a better route?
ABI Home Services
Member
Philly, PA
[#9] Posted: Feb 05 2010 - 7:22:19 PM
If you eliminate voltage drop, the suretest is basically giving you the same info as a 10$ 3 lite tester.
View Profile
[#10] Posted: Feb 05 2010 - 7:30:27 PM
No, that's not so. Suretests just give more information than the average HI -or electrician for that matter- can accurately interpret. They're good, but like a hammerdrill, they're just not great tools for HI's.
Jimmy
View Profile
Member
louisville, ne
[#11] Posted: Feb 07 2010 - 6:29:07 PM
Do any of you guys check the voltage at the main coming into the panel? that would tell you which side the voltage drop is coming from,or am I thinking like a contractor again?
http://hyetechutilities .com
View Profile
Senior Member
[#12] Posted: Feb 07 2010 - 6:40:39 PM
Quote: Do any of you guys check the voltage at the main coming into the panel? that would tell you which side the voltage drop is coming from,or am I thinking like a contractor again?
Relax Jim. We're both contractors.
You're right on cue about checking voltage drop near the panel to get an idea how much of the impedance at a problem VD location is due to the premises wiring and how much is due to utility line impedance.
Marc
View Profile
Administrator
Chicago, IL
[#13] Posted: Feb 07 2010 - 8:08:10 PM
This is one of those things that's not enforceable (per Garet's explanation), so is it a defect? Is there anything we can go to that says it's a real problem?
Not really.
I stopped reporting it years ago. Every house has it, at least every house I've looked at.
Kurt in Chicago
Workin' the Inner City
"Things are more like they are now than they ever have been before"
Dwight D. Eisenhower
View Profile
Editor - TIJ
Kenmore, WA
[#14] Posted: Feb 07 2010 - 9:30:59 PM
I wouldn't toss the SureTest. It comes in really handy when you have a house with aluminum wiring for pinpointing excessively high voltage drop that can indicate a corroded copper-to-aluminum connection.
Mike
View Profile
Administrator
Chicago, IL
[#15] Posted: Feb 07 2010 - 9:56:44 PM
True, but if I find aluminum wiring, I'm already going into danger mode and will be recommending all sorts of things.
I really don't need the Suretest to tell me that. And yes, I do have a carry a Suretest. Use it every day. Just not for determining voltage drop.
Kurt in Chicago
View Profile
Senior Member
Gervais, Oregon
[#16] Posted: Feb 07 2010 - 10:10:38 PM
Maybe it's just mine, but I don't trust the suretest. It often seems to give me bogus readings.
One of my plans this year is to spend more time looking at a homes electrical system under load with my IR camera. I wonder what correlation exists between what the suretest says vrs infrared?
My guess is the correlation is poor.
Chris, Oregon
Jump To:
The Inspector's Journal Forums © 2002-2010 all topics or replies that are posted on The Inspector's Journal
Go To Top Of Page
Pick an RSS Feed
© 2002-2009 Copyright DevWave Software Inc.
Find a Home Inspector
Powered By: Snitz Forums 2000
