Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
 All Forums
 Technical Forums
 Electrical Forum
 Square D double tap
Home Inspection Software designed for the professional Home Inspector!
Previous Topic: Reversed polarity Outlets - Topic - Next Topic: AL in Panel New TopicReply to TopicShare Topic Printer FriendlyBookmark this Topic
Posted By
View Profile
Senior Member
Severna Park, Maryland
Currently offline offline
Thread Start First Page
[#1] Posted: Feb 25 2010 - 05:09:45 AM
Here is a picture of print on a Square D breaker. It shows the allowance for two conductors to be attached. I know the question comes up from time to time. I thought the picture turned out good so I decided to post it here in case anyone wants to use it for reference.
Click to View
Image Unavailable! Sorry you must be logged in to view images.
Click Here For Free Registration
45.88 KB
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
View Profile
Member
Sykesville, Maryland
Square D double tap
[#2] Posted: Feb 25 2010 - 11:22:54 AM
Good pic, thanks for sharing. Charlie
"your home inspector shoulda seen that, hon."
View Profile
Active Member
Louisville, KY
Currently online online
Square D double tap
[#3] Posted: Feb 25 2010 - 11:49:46 AM
Nice, thanks man!
ABI Home Services
Louisville Home Inspections
Louisville Home Inspectors
View Profile
Active Member
Ridgewood, NJ
Square D double tap
[#4] Posted: Feb 25 2010 - 11:54:13 AM
John, here's a quiz for you. What does the SWD mean on the breaker?
Neal Lewis
www.totalhomeinspectionservices.com
View Profile
Senior Member
Collins, NY
Square D double tap
[#5] Posted: Feb 25 2010 - 12:16:17 PM
Oooh, I know! I know!
Actually, I didn't know. I had to go look it up. Now that I have the answer, I gotta say that is a really dumb place for the designation.
Thank you for the opportunity to learn something.
Tom
Clear Creek Home Inspection, Collins, NY
View Profile
Senior Member
Square D double tap
[#6] Posted: Feb 25 2010 - 2:42:29 PM
I don't know. What does it mean?
View Profile
Active Member
Ridgewood, NJ
Square D double tap
[#7] Posted: Feb 25 2010 - 4:51:16 PM
Switching Device. For instance, light fixtures in some commercial properties might not have a switch, just turned off with the breaker.
Neal Lewis
View Profile
Senior Member
Square D double tap
[#8] Posted: Feb 25 2010 - 6:42:41 PM
So SWD means it is designed to be used as a regular means of turning things on and off. Hmmmm, now I know. Thanks for pointing that out.
What other designations might one find on Square D's?
Member
Victoria, British Columbia
Square D double tap
[#9] Posted: Feb 25 2010 - 6:57:26 PM
Click to View
45.88 KB
Hey John. Another quiz. Can those conductors be different guages? Like a #12 and a #14 on a 15 amp breaker?
View Profile
Senior Member
Square D double tap
[#10] Posted: Feb 25 2010 - 7:12:07 PM
Click to View
45.88 KB
Thats another good question that I do not immediately know the answer to. I know you shouldn't have a #14 wire on a 20amp breaker.
Obviously, the printing on the breaker doesn't specify anything about mixing wire sizes. It does say 10-14, but I don't know if that means you can mix sizes.
Give it up John, please.
View Profile
Associate Editor - TIJ
Gaston, Oregon
Square D double tap
[#11] Posted: Feb 26 2010 - 12:40:30 AM
Both Square D and Cutler hammer allow you to combine different size wires (though there are few situations where you'd want to). You can also combine stranded and solid.
If you're attaching only one wire, both manufacturers will allow you to use either copper or aluminum. However, if you're attaching two wires, they both must be copper.
- Jim Katen, Oregon
View Profile
Senior Member
Kenmore, WA
Square D double tap
[#12] Posted: Feb 26 2010 - 06:41:32 AM
To be clear and if I'm not mistaken. . .
Not all Square D breakers are allowed to be double tapped.
That photo is a Square D Homeline breaker. The QO breakers from Square D do not allow double taps. It's easy tell the two apart (if for some reason the breakers were never id'd) because the Homeline have the metal saddle terminal that easily accepts two wires just like the diagram shows.
Randy Navarro
http://www.thecompleteinspection.com
View Profile
Gaston, Oregon
Square D double tap
[#13] Posted: Feb 26 2010 - 08:49:27 AM
Both the HOM and the QO breakers in the 1-, 2-, & 3-pole configuration in the 10amp-30amp range have the double saddle and will accept two wires. Just check the catalogue.
- Jim Katen, Oregon
Member
Olympia, WA
Square D double tap
[#14] Posted: Feb 26 2010 - 09:05:31 AM
- Jim Katen, Oregon
Some of the Cutler Hammer breakers are listed for more than one wire (15-30 amp). As stated above the Square D and Homeline are also listed for more than one wire. Of course the load on the circuit could be an issue. Here is a picture of a CH breaker (I had to highlight it to get it to show up - the printing is just embossed in black).
Click to View
36.32 KB
Jim P. Simmons
Master Electrician
Washington
View Profile
Senior Member
Kenmore, WA
Square D double tap
[#15] Posted: Feb 26 2010 - 4:14:25 PM
- Jim Katen, Oregon
Okey doke. I stand corrected. I don't remember, though, that the saddles/terminals look the same. I couldn't find a clear enough picture in the catalog.
Randy Navarro
View Profile
Seattle, WA
Square D double tap
[#16] Posted: Feb 26 2010 - 4:42:49 PM
This is a QO breaker lug. I'm 99.99% certian they are exactly the same as the homeline ones.
Click to View
44.06 KB
Richard Moore
Rest Assured Inspection Services
Seattle, WA
http://www.rainspect.com
View Profile
Senior Member
Kenmore, WA
Square D double tap
[#17] Posted: Feb 26 2010 - 8:53:55 PM
I think there is a difference. Now I'm splitting hairs 'cuz all the Square D breaks accept two wires anway.
On the QO breaker, all I see is that big fat screw head facing me as I look in the panel - the saddle is tucked underneath and sort of hidden by the plastic.
On the Homeline breaker, the saddle is actually visible from the front of the panel.
I could be wrong again. . . but I don't think so. I need to be right about something every now and then. . .
Randy Navarro
View Profile
Active Member
Ridgewood, NJ
Square D double tap
[#18] Posted: Feb 27 2010 - 05:53:14 AM
Well, that part of your response is wrong. For example, Square D QO breakers over 30 amp and tandems aren't made for double taps.
Neal Lewis
View Profile
Senior Member
Kenmore, WA
Square D double tap
[#19] Posted: Feb 27 2010 - 1:49:05 PM
Okay, okay. . . I meant the Square D breakers specifically in this discussion.
Randy Navarro
View Profile
Senior Member
Sagamore Hills, Ohio
Square D double tap
[#20] Posted: Feb 27 2010 - 2:13:58 PM
- Jim Katen, Oregon
Jim, if you use two different gauge wires wouldn't it torque more on the larger wire leaving the smaller wire loose?
Terry
http://www.hlis.net
View Profile
Seattle, WA
Square D double tap
[#21] Posted: Feb 27 2010 - 3:08:51 PM
- Jim Katen, Oregon
Look at the photo I posted a little earlier. The Square-D top plate "floats" and is pushed down by the rounded underside of the screw. It will rock a bit side to side to accomodate different sized conductors. That's the Square-D...the Cutler Hammer version (photo below) is different and, IMO, doesn't look as capable as the Square-D.
Click to View
84.44 KB
Richard Moore
Seattle, WA
View Profile
Gaston, Oregon
Square D double tap
[#22] Posted: Feb 27 2010 - 3:17:14 PM
- Jim Katen, Oregon
Yes, it will probably apply more pressure on the larger wire, but the pressure plate will rock and apply enough pressure on the smaller wire as well. This is probably one of the reasons why you're supposed to tighten these lugs to 36 in-lbs.
- Jim Katen, Oregon
View Profile
Gaston, Oregon
Square D double tap
[#23] Posted: Feb 27 2010 - 3:29:03 PM
Quote: Originally posted by Richard Moore
...the Cutler Hammer version (photo below) is different and, IMO, doesn't look as capable as the Square-D. . . .
Your photo doesn't clearly show the notch at the bottom of the clamp. Also the pressure plate has a dimple in it that locks the wires in place. Once you stick a couple of wires in there and tighten the lug to 30 in-lbs, those wires ain't going nowhere.
Frankly, the same could be said for most manufacturer's breakers. The big difference is that most manufacturers didn't pay to have UL list their breakers for 2 wires.
- Jim Katen, Oregon
Member
Square D double tap
[#24] Posted: Mar 04 2010 - 7:19:16 PM
Click to View
45.88 KB
Sorry, John D, I forgot I asked it. And I admit I wasn't sure myself. We got an answer.
Jump To:
The Inspector's Journal Forums © 2002-2010 all topics or replies that are posted on The Inspector's Journal
Go To Top Of Page
Pick an RSS Feed
© 2002-2009 Copyright DevWave Software Inc.
Find a Home Inspector
Powered By: Snitz Forums 2000
