| Posted By |
lakeway, tx Posts: 2
| offline |
Thread Start First Page [#1] Posted: Mar 09 2010 - 08:18:20 AM |  | |
Something about this didn't make intuitive sense to me, but I'm not a roofer.
Click to View Image Unavailable! Sorry you must be logged in to view images. Click Here For Free Registration 46.93 KB
| KevinO |
 Member
Evanston, Illinois Posts: 280
| offline |
Does this tile roof look right?
[#2] Posted: Mar 09 2010 - 09:12:55 AM |  | |
The hip/ridge cap should not be installed on the gutter edge. There should be a gutter there and I imagine that there is not one because the contractor who installed the other gutters could not figure out how to make a curved gutter. Or maybe some other reason.
An old mentor of mine used to tell me to "be water". When I "be water" on this roof, I could/will: run down the side of the house and erode the facade leak into the house through the windows/rot the windows erode the soil at the foundation cause foundation leaks
Just a whole list of bad stuff that could be solved with a simple gutter system.
| Cary |
 Senior Member
Lafayette, Louisiana Posts: 1103
| offline |
[#3] Posted: Mar 09 2010 - 10:11:47 AM |  | |
Odd looking trim installed on the 2nd story eaves and no gutter on same. Not that the gutter is required but that I don't see how the contractor rationalized gutters just on the 1st story and not the 2nd story. I wish there was a way to confirm the presence of a steel moment frame in that center wall with all those fenestration openings, because that wall doesn't seem to be in the same plane as the walls on either side. And look at the valleys on either side. A wall projects halfway into them. It's a flashing nightmare unless it's well soldered copper.
Marc
 Associate Editor - TIJ
Gaston, Oregon Posts: 5386
| offline |
 Active Member
Evergreen Park (Chicago), IL Posts: 589
| offline |
[#5] Posted: Mar 09 2010 - 1:17:15 PM |  | |
Quote: Originally posted by Jim KatenQuote: Originally posted by stiches9
Something about this didn't make intuitive sense to me, but I'm not a roofer. The roofer probably did what he could when faced with such a stupid design. People who design this crap really need to get a clue. - Jim Katen, Oregon
They are called, "architects."
 Senior Member
| offline |
[#6] Posted: Mar 09 2010 - 1:45:11 PM |  | |
I didn't realize this until after my first post but that center wall appears to be a convex shaped wall (from the outside) except for a horizontal foot or two from each side. That might explain the odd eaves trim: The contractor couldn't, or didn't want to cut the clay tiles, so he 'patched' it with the trim pieces. One wonders if there is a problem with the roof finish at that point. Sounds like ample motivation to get a long extension ladder. Might be lots of trouble but might be an important finding too.
Marc
 Editor - TIJ
Kenmore, WA Posts: 12154
| online |
[#7] Posted: Mar 09 2010 - 3:03:39 PM |  | |
Someone's clumsy attempt at an asian influenced cloud lift roof without any overhangs or a clue as to what he/she was doing.
ONE TEAM - ONE FIGHT!!!
Mike
 Senior Member
Sagamore Hills, Ohio Posts: 2396
| offline |
[#8] Posted: Mar 09 2010 - 3:53:21 PM |  | |
Another weak spot will be where the valley hits the wall. The stone and mortar will be constantly saturated. Who knows what's going on with the other side.
Not a very goog design for sure.
Edit: I see that Marc already pointed this out.
Click to View Image Unavailable! Sorry you must be logged in to view images. Click Here For Free Registration 47.1 KB
After some reasearch I see that a Ms. Lisa was the design engineer.
Click to View Image Unavailable! Sorry you must be logged in to view images. Click Here For Free Registration 3.04 KB
Terry
http://www.hlis.net
| offline |
[#9] Posted: Mar 10 2010 - 11:30:09 AM |  | |
Thanks for the great input - I only noticed the strange ridge cap where the gutter would be, but you guys found other stuff... Since I'm not working on the house itself, I'm trying to figure out a diplomatic way to approach this as we prepare a bid for outdoor kitchen, patio, firepit, etc. outside. Any comments would be most appreciated.
(maybe I'll have Ms. Lisa talk to them ;-))
| KevinO |
 Senior Member
| offline |
[#10] Posted: Mar 10 2010 - 12:58:07 PM |  | |
Well, since you didn't build the house, I would avoid mentioning any of the stuff we found to your customer. Customers have a way of sticking your name on things that you didn't even do if you so much as mention them. It's psychology. Stick with the outdoor kitchen, etc and do it right. Do it proudly.
Marc
New Member
Melbourne, Victoria Posts: 28
| offline |
[#11] Posted: Apr 28 2010 - 4:12:02 PM |  | |
They are called, "architects." [/quote]
Hi there, I'm a roofing contractor.
In Australia of late, architects have started to move back to a more standard roofing design. We went through a stage there where it got pretty ridiculous. Hips and valleys that that ran no-where. hips in places they didn't need to be etc. Roofs when finished were not functional and on many occasions, major rectifications were needed. Possibly bad training?
A big elegant house i can understand having intricate roofing designs, but leave the average house alone i say!
cheers.
| Roof Restoration Melbourne - 0401 004 294 |
