| Posted By |
Lake Country, Wisconsin Posts: 106
| offline |
Sagamore Hills, Ohio Posts: 3113
| offline |
Chicago, IL Posts: 9553
| offline |
Combination systems help
[#3] Posted: 04/04/2010 - 09:11:31 AM |  | |
You've already made the most informative observations; they're Armstrong and Goodman, and they're about 10-12 years old when they kick.
In the age of globalization, when parts can come from anywhere, and are assembled somewhere else, there can be little to no quality control of individual components.
I just make sure they're installed to the mfg's. spec's as well as possible, I verify that they heat and cool, that they exhaust satisfactorily, and I note the age. I tell folks they're cheap junk, they can run fine for 20 years, or fail tomorrow, and to understand that they could fail at anytime after I walk out the door.
I used to get a lot more techie about them, but it's pretty cut and dried nowadays.
Kurt in Chicago
louisville, ne Posts: 354
| offline |
[#4] Posted: 04/04/2010 - 12:32:44 PM |  | |
do you have a picture of one of these units? only issues i generally find with goodman furnaces are igniters and occasional noisy inducer motor. ive found lots of trane heat exchangers cracked on the other hand,usually late 80s-early 90s 80% stuff.i was finding cracks in trane equipt back in the early-mid 90s
| offline |
[#5] Posted: 04/04/2010 - 1:13:01 PM |  | |
Jim, look for a private PM.
Terry
http://www.hlis.net
This space for let - please inquire within.
Lafayette, Louisiana Posts: 3918
| offline |
| offline |
| offline |
| offline |
[#9] Posted: 04/04/2010 - 2:48:54 PM |  | |
Quote: Originally posted by MarcQuote: Originally posted by Terence McCann
Nonsense.
A filter dryer is more of an insurance policy for shotty service after the fact. Actually, when you do things correctly, a filter dryer isn't needed.
Tell me...how do you service the refrigerant circuits on a small self contained system like a window unit? Marc
You throw them away and buy a new one.
Terry
http://www.hlis.net
| offline |
[#10] Posted: 04/04/2010 - 2:51:34 PM |  | |
Right! So shouldn't they have a filter dryer installed? You can replace the dryer but you can't practically clean out or replace the capillary tubes. They're too small.
Marc
