Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
Siding over siding question
Previous Topic: Big Crack! - Topic - Next Topic: New OH Garage Door Opener New TopicReply to TopicShare Topic
Posted By
View Profile
Pottstown, Pa
Currently offline offline
Thread Start First Page
[#1] Posted: 10/05/2010 - 11:47:59 AM
I was at a house today, 33 year old, that had vinyl siding installed over metal siding (evident by the electric meter). What do you guys tell your clients when you encounter this?
"When the only tool you have is a hammer, everything looks like a nail"
View Profile
Newberg, OR
[#2] Posted: 10/05/2010 - 12:03:47 PM
Quote: What do you guys tell your clients when you encounter this?
Assuming that everything looks like it's in good shape and was well installed, I'd tell my client that it looks like they are well protected against moisture intrusion.
Can't say I've ever seen vinyl installed over metal...........
Brandon
Portland Home Inspector
View Profile
Pottstown, Pa
[#3] Posted: 10/05/2010 - 12:26:05 PM
I have seen it before, but usually it is poorly installed (windows sunk in due to lack of clearance etc...). This time i wouldn't have even noticed except you could still see the metal behind the electric meter.
Click to View
47.43 KB
Water was following that communication wire on the right into the home and dripping inside the electrical panel! bzzzt!
View Profile
Lafayette, Louisiana
Currently online online
[#4] Posted: 10/05/2010 - 4:57:48 PM
I might wonder if the vinyl had a proper nail base and was properly installed.
Marc
Allentown, NJ
[#5] Posted: 10/15/2010 - 05:56:47 AM
The attachment would be my biggest concern, on the other hand, I see vinyl siding over asbestos-cement siding all the time !!
Rick Lobley
http://www.doublecheckhi.com
View Profile
Ashland, VA
[#6] Posted: 10/15/2010 - 09:32:09 AM
Like Brandon says, if it's installed well, I just tell folks "It's like having two overcoats on!"
"This above all: to thine own self be true." - William Shakespeare
View Profile
Rochester, New York
[#7] Posted: 10/15/2010 - 10:00:40 AM
It doesn't look like vinyl over metal to me. It looks like it had aluminum siding and it was removed except from behind the meter and then the meter box was replaced with a smaller unit, exposing some of the old siding.
Maybe it's the photo, but it looks like the metal and the vinyl are almost flush.
Chad Fabry
StructureSmart Home Inspection Rochester, NY
www.structuresmart.com
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
