| Posted By |
DeWitt, Mi Posts: 3305
| offline |
Lafayette, Louisiana Posts: 3858
| offline |
Good work!
[#2] Posted: 11/02/2010 - 06:14:11 AM |  | |
I got threatened about 3 weeks ago via a phone call from the builder of a new construction. It was an FHA inspection that I did there and he didn't like me holding up the sale. Remember the thread with the street pole in the middle of the sidewalk? Him! And it wasn't the street pole that failed that inspection. There used to be an FHA inspector, 90 minutes from me who, for over 10 years, passed ANYTHING for the right price. I just checked the roster at HUD, he's no longer there. Progress?
Les, plumbing isn't my forte. What's wrong with the plumbing? Unless you're referring to the disfigured stud.
Marc
Georgetown, KY Posts: 2179
| offline |
Friday Harbor, WA Posts: 502
| offline |
Good work!
[#4] Posted: 11/02/2010 - 08:01:51 AM |  | |
What's on the other side of the drywall? And, how often are you guys seeing those sharkbite fittings?
Calgary, AB Posts: 512
| offline |
Good work!
[#5] Posted: 11/02/2010 - 11:53:22 AM |  | |
If the valve is a single lever Moen valve ...then it's all wrong
The valve is missing support, a 2x4 on the flat flush with the backside of the wall framing will usually work out well with 1/2" wallboard and wall tiles. This is most critical with PEX lines as they don't provide much support as copper would.
The 'rough-in' template (white opaque plastic disk in front of the valve against the wallboard) should have been installed flush with the FINISHED wall. This plate is a guide in locating the valve body and protects the rough-in from construction damage, it's thrown away by the finish plumber. I'm thinking the valve is too far inside the wall for the lever to shut off the water ... Are the two lines running inside the exterior wall?
RC www.YourCalgaryHomeInspector.com |
Collins, NY Posts: 3143
| offline |
Good work!
[#6] Posted: 11/02/2010 - 12:53:38 PM |  | |
Could be worse Les, it could be going in 203k and some newb could spend the next 6 months continuing to trash it while we foot the bill for his rehab too
Tom
