Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Plumbing Forum >
Washing machine drain setup
Previous Topic: Ebony and ivory... - Topic - Next Topic: Stack Vent To Appliance Vent Clearance New TopicReply to TopicShare Topic
Posted By
View Profile
Lakewood, WA
Currently offline offline
Thread Start First Page
[#1] Posted: 04/13/2011 - 9:22:43 PM
Can't say that I have ever seen this setup before. 90+ year old home, washer and dryer "relocated" to the utility basement. What is visible in this pic is the hose connected to the home's drain line. In the second pic it shows the white drain line which is also part of the washing machine drain line. I don't think I have ever seen a "t" like that.
Click to View
63.12 KB
Click to View
59.06 KB
Rob Jones
South Sound Inspections
Seattle Home Inspection
"If you work just for money, you'll never make it, but if you love what you're doing and you always put the customer first, success will be yours."
Ray Kroc
Friday Harbor, WA
[#2] Posted: 04/13/2011 - 9:50:29 PM
That fitting is called a "cross" and it's not supposed to be installed on its side like that. I've only seen those in cast iron, never plastic.
View Profile
Chicago, IL
[#3] Posted: 04/13/2011 - 10:12:23 PM
It's a standard fitting, installed completely wrong.
Kurt in Chicago
View Profile
State: PA & NJ
[#4] Posted: 04/13/2011 - 10:27:35 PM
It's a double sanitary tee (and it's on its side). I see them quite frequently, like when 2 horizontal drains transition to vertical.
A "cross" tee is a bit different:
Click to View
4.7 KB
Bill Kibbel, Historic & Commercial Building Inspections - Old House Resources
View Profile
Lakewood, WA
[#5] Posted: 04/14/2011 - 08:37:40 AM
Thanks guys.
Rob Jones
Ray Kroc
View Profile
Victoria, British Columbia
Currently online online
[#6] Posted: 04/14/2011 - 08:48:49 AM
That white flex hose is what they sell at the big box for dishwasher hookups, I think. It restricts the flow too much for a clothes washer, IMO. And there could be trouble, since they are blowing water in under pressure in a crawlspace.
Just so happens, I had one of those T's on the main stack yesterday. Two back to back toilets upstairs, 1979 house.
My washing machine hookup was also kaka. I believe the stand pipe is too short.
Click to View
57.19 KB
Click to View
44.39 KB
Click to View
42.88 KB
www.allsafehome.ca
View Profile
Canton, Ohio
[#7] Posted: 04/15/2011 - 12:13:57 AM
Are washing machines designed to pump water that high? With the flex pipe and the kink at the end, the washing machine has to work overtime to pump water. And where's the trap?
Maybe it's the angle of the picture, but that horizontal drain looks like it is sloped the wrong way.
Ezra Malernee
Canton, Ohio
www.ezrashome.com
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
