| Posted By |
gledale, az Posts: 4
| offline |
Lafayette, Louisiana Posts: 3846
| offline |
hail damage to tile roof causing polka dot look
[#2] Posted: 08/18/2011 - 11:01:50 AM |  | |
It might be a good investment to ramp up your technical representation from roofing contractors to a home inspector who offers expert witness services.
Marc
Gaston, Oregon Posts: 8080
| offline |
[#3] Posted: 08/18/2011 - 11:13:55 AM |  | |
Do you have any good pictures?
Collins, NY Posts: 3138
| offline |
[#4] Posted: 08/18/2011 - 11:45:06 AM |  | |
Lemme get this straight. You've got visible spots on your roof from a hail storm 10 months ago and your fighting with your insurance company about replacing them now. Sound right?
I wouldn't hold my breath if I were you. If it wasn't under water or spun to bits by tornado it was on fire. Underwriters are buried in claims. They never even sent an adjuster to see this poor guy.
Click to View
 81.21 KB
Click to View
 88.49 KB
Click to View
 57.63 KB
Tom
DeWitt, Mi Posts: 3305
| offline |
[#5] Posted: 08/18/2011 - 12:00:35 PM |  | |
Jacki, There are two of the very best expert inspectors in your state; Scott Warga http://www.acsillc.com/ and Paul Staron. Both are good guys and would be your best resource. Sorry I do not know Paul's website.
They are not as handsome as me, but they are quite good never the less!
Les
| offline |
[#6] Posted: 08/18/2011 - 6:26:30 PM |  | |
have printed pictures on regular paper from engineer but no disc and don't know how to add to this page, have been fighting with ins co since 12/10 it took several months to get roofer out
| js |
| offline |
Peoria, Arizona Posts: 131
| offline |
[#8] Posted: 08/19/2011 - 06:05:01 AM |  | |
JS
Glendale and Peoria both received quite a bit of damage when the hail storm came through last year. However, I'm not sure what polka dot damage is. I have been seeing a lot of damage that looks more like golf ball damage. (broken, chipped, cracked, displaced, and missing tiles)
If I were to guess, I assume that some of the glazing got chipped off the tiles. However, we would need some pictures to know for sure.
I don't recall if you said, were these clay tiles or concrete tiles? Did you have any other damage such as broken tiles or dented flashing?
I still have a couple of reputable roofing companies stop by my house every week trying to sell me a new roof. However, they are all driving trucks with out of state license plates. It does tend to make you wonder.
Post some pictures when you get a chance and maybe we can give you some advice.
Jeff Euriech Peoria Arizona
Kenmore, WA Posts: 15388
| offline |
[#9] Posted: 08/19/2011 - 5:27:10 PM |  | |
Scan your pictures and save them to your hard drive as JPEG pics. Resize them if necessary to get them under 200Kb each. When you name the file don't leave any spaces in the name or use special symbols.
This: DamagedRoofTile_1 or Damaged_Roof_Tile1
Not: Damaged Roof Tile #1 or Damaged Roof Tile (#1).
Do not use the quick reply box to respond. Instead, click on the 'reply to topic box' immediately below the last post read. Then use the Insert Visible Photo icon below the composition box to insert your photo. Click on that button, browse to the photo on your hard drive, click to upload it, wait for the software to tell you that it's done and then close the sub-window and go onto your next picture. When you're all done uploading all the pictures, submit the post and the pictures should display.
ONE TEAM - ONE FIGHT!!!
Mike
Gilbert, Arizona Posts: 419
| offline |
[#10] Posted: 08/23/2011 - 9:11:04 PM |  | |
I had to chime in.
Les, thanks for the plug. (Even if I am not as good looking as you)
We have lots of tile roofs in this area and some of them (from the 70s & 80s) have a finish on them that oxidizes like paint.
They get very slick when wet. (I slid down one last April)
The hail hit different parts of the valley and made some of these roofs look spotted when the hail blasted the oxidation right off of the tile.
I have seen this on about 10 different roofs since the storm last October. I also found broken tiles on each of these roofs.
The insurance adjusters look at the oxidation as a cosmetic issue and the broken tile repair likely will be less than the deductible.
I know that is not the answer he is looking for but the foam and shingle roofs are the ones that the insurance companies are replacing, and most of them are only paying for partial replacement.
On a different note, go check the fins on your air conditioning unit. If the hail was hard enough to spot the roof it likely damaged the fins on the AC unit.
Scott Warga ACSI American Construction Specialists & investigations Arizona |
