Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Electrical Forum >
tubs and fireplaces
Previous Topic: romex inside conduit - Topic - Next Topic: Electrical Mismatch New TopicReply to TopicShare Topic
Posted By
bow, wa
Currently offline offline
Thread Start First Page
[#1] Posted: 01/08/2012 - 5:43:55 PM
i have a soaker tub in my bathroom with a two sided fireplace that i am installing. i am trying to find the minimum distance i can put the fireplace to the tub when the actual fire is at the level of the top of the tub. thank you.
View Profile
Member
McLouth, KS
tubs and fireplaces
[#2] Posted: 01/08/2012 - 6:20:10 PM
OK, I have to ask, why do you want a fireplace in the bathroom? Regardless of all the issues that could be involved with such a location, I'll focus on one issue....Slip and falls in the bath room could be re-written if you slipped then fell on a fireplace.
Now mind ya of his, its your money and you can do with it as ya please. I have never saw a bathroom with a fireplace ever in my life.
View Profile
Active Member
louisville, ne
tubs and fireplaces
[#3] Posted: 01/08/2012 - 6:24:06 PM
Id say in the next room would be aq good safe distance myself,how did this end up in the electrical forum anyway?
View Profile
Senior Member
Georgetown, KY
tubs and fireplaces
[#4] Posted: 01/08/2012 - 7:32:26 PM
I've seen several of those two sided fireplaces around here installed in the wall between the master bedroom and the master bathroom with the fireplace right at the end of the soaker tub.
While the ones I've seen had the flame elevated above the level of the tub, I'd suggest that your best source of information is to contact the manufacturer directly and ask them.
View Profile
Associate Editor - TIJ
State: PA & NJ
tubs and fireplaces
[#5] Posted: 01/08/2012 - 8:11:27 PM
Is this actually a fireplace, or a "gas-fired decorative appliance"?
View Profile
Senior Member
Collins, NY
tubs and fireplaces
[#6] Posted: 01/09/2012 - 05:33:26 AM
It can't be gas, the code prohibits gas fired appliances in toilet rooms.
View Profile
Senior Member
Nazareth, PA
tubs and fireplaces
[#7] Posted: 01/09/2012 - 05:53:43 AM
Tom, I think there is an exception if a fire extinguisher is located near the source of the gas.
Click to View
52.02 KB
View Profile
Member
Linden, MI
tubs and fireplaces
[#8] Posted: 01/09/2012 - 06:16:08 AM
I always thought the problem was that you could not draw combustion from a bathroom or a bedroom not that you could not have a gas appliance in those rooms.
Many fireplaces and decorative gas appliances have vents to draw combustion air from outside. Also un-vented gas logs are not allowed in bathrooms and bedrooms.
As far as the clearance from the bathtub I don't think it's addressed in the code and I doubt it's covered in any installation manual.
View Profile
Founder - TIJ
Kenmore, WA
tubs and fireplaces
[#9] Posted: 01/09/2012 - 09:09:28 AM
These are typically direct-vent gas appliances so the code prohibition re. combustion air doesn't apply to them. They are installedi only in master baths so that children and guests don't use them. The glass used is safety glass and the electrics underneath are GFCI protected. Gas fireplaces are like gas stoves - they don't require a hearth in front. I see a couple of dozen a year in new construction.
Everything the O.P. needs to know is in the installation manual for the fireplace. The manufacturers know that folks put these at the head of tubs and they address it in their manuals.
ONE TEAM - ONE FIGHT!!!
Mike
New Member
Castle Rock, co
tubs and fireplaces
[#10] Posted: 01/09/2012 - 10:02:31 AM
I'm speculating you haven't been around much - I've been around plenty of them - normally in a master bedroom / bath combination.
Whew!
View Profile
Founder - TIJ
Kenmore, WA
tubs and fireplaces
[#11] Posted: 01/09/2012 - 3:05:02 PM
It's just regional differences.
I'm sure there are things in Kansas that I'd never see out here in Washington state and I'm sure there are things out here that you'd never see in Colorado.
ON TEAM - ONE FIGHT!!!
Mike
View Profile
Senior Member
Victoria, British Columbia
tubs and fireplaces
[#12] Posted: 01/09/2012 - 8:33:15 PM
Quote: Originally posted by Inspectorjoe
Click to View
52.02?KB
Don't do it. Methane gas is extremely flammable.
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
