Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Interiors & Appliances >
Thermal Pane Tempered Glass with Hole/Crack in it
Previous Topic: Garage wall stain - Topic - Next Topic: we took the kitchen when we moved out New TopicReply to TopicShare Topic
Posted By
View Profile
Evergreen Park (Chicago), IL
Currently offline offline
Thread Start First Page
[#1] Posted: 02/25/2012 - 3:21:55 PM
The thermal pane window next to this bathtub is marked as tempered glass. The exterior glaze is cracked with a BB hole in it. The glass would crumble if it were tempered. Correct?
Is only the interior glazing required to be tempered?
Click to View
20.16 KB
Mike Lamb
http://www.inspection2020.com/
View Profile
Gaston, Oregon
[#2] Posted: 02/25/2012 - 5:15:15 PM
If it borders a tub or shower the inboard and outboard panes are both required to be safety glazed.
There is an exception for outboard panes, but it doesn't apply to windows bordering tubs or showers. It says that the outboard pane in an insulated glass unit is exempt from the safety glazing requirement if its bottom edge is more than 25 feet above grade, a roof, walking surfaces, or other horizontal surfaces adjacent to the glass. This exception only applies to glazing that's more than 9 square feet in area, that has a bottom edge that's less than 18" from the floor, and a top edge that's more than 36" above the floor and that's near a walking surface. If one of these glazed areas is near a door or over a tub or shower, then the exception doesn't apply.
Jim Katen, Oregon
www.amipdx.com
View Profile
[#3] Posted: 02/25/2012 - 5:46:31 PM
Thanks.
It seems deceptive practice. This window is made by ClimateGuard of Chgo. Home Depot sells them, I think or used to.
I consider ClimateGuard a good cheap window.
Mike Lamb
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
