Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Miscellaneous Discussion Forums > Open Discussion Forum (Chit-Chat) >
drywall / cement board joint
Previous Topic: Electrolysis for rust removal? - Topic - Next Topic: Two in a row! New TopicReply to TopicShare Topic
Posted By
View Profile
Severna Park, Maryland
Currently offline offline
Thread Start First Page
[#1] Posted: 04/16/2012 - 06:06:51 AM
Hi folks,
I'm mudding the walls now. How should I handle the joint at the ceiling of the shower area where the tiles will go up to the ceiling? This is where Hardie Backer and drywall come together to form the inside corner joint at the ceiling.
I was planning on finishing all the drywall and painting before beginning to set any tile.
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
View Profile
Collins, NY
[#2] Posted: 04/16/2012 - 06:37:17 AM
The same way you handled the other drywall to Hardie joints, except you may want to use a corner trowel.
Tom
Dr Joe Lstiburek
View Profile
Oswego, NY
[#3] Posted: 04/16/2012 - 06:50:16 AM
If you're going to use a corner trowel, close the door so your friends won't see you with it.
I'm Gary Blum and I approve this message
www.gtbinspectionservices.com
View Profile
[#4] Posted: 04/16/2012 - 11:28:01 AM
On the vertical surfaces I have the drywall terminating a couple of inches under where the tile will end so those joints are not relevant since they will be covered with thinset. The only joint with any exposure is the one I mentioned.
Unless anyone has a better idea, I guess I'll use drywall tape and not pay too much attention to the Hardie side since the tile will cover that part.
View Profile
Collins, NY
[#5] Posted: 04/16/2012 - 12:59:07 PM
Blum, that reminds me of a joke my mother told me when I was a teenager.
What do fat girls and mopeds have in common?
They're both fun to ride until your friends see you on one!
Tom
Dr Joe Lstiburek
View Profile
Chicago, IL
[#6] Posted: 04/16/2012 - 3:56:03 PM
Durabond 90. Mud one side of the corner, let it dry, then mud the other side. It's easier for beginners that way; doing them both at once isn't hard, but it's a little tricky for first timers.
I have a corner trowel hidden somewhere......
Kurt in Chicago
Friday Harbor, WA
[#7] Posted: 04/16/2012 - 4:59:27 PM
Doesn't matter what tools you use inside the house, as long as your friends see you outside washing your bazooka.
Personally, I don't know that I'd bother running tape down from the ceiling onto the backerboard walls. I'd rather stick tile to clean backerboard than drywall mud.
View Profile
Chicago, IL
[#8] Posted: 04/16/2012 - 5:02:35 PM
Or, Dave's way. it's easier and works great.
Kurt in Chicago
View Profile
Oswego, NY
[#9] Posted: 04/16/2012 - 6:43:49 PM
Quote: Blum, that reminds me of a joke my mother told me when I was a teenager.
Your mother? Are you shitting me?
Friday Harbor, WA
[#10] Posted: 04/16/2012 - 8:18:42 PM
If my mother heard me tell that joke, she'd beat me.
View Profile
[#11] Posted: 04/17/2012 - 03:35:02 AM
This is the first time I've done an entire room.
I used a corner trowel to set the tape but went to a 12" knife for the rest. Place in corner and spread outwards.
I used the following video as a tutorial. I like the goal of minimal sanding. Knocking down ridges before the mud totally sets seems helpful.
http://www.youtube.com/v/a1QSVX7SiCo
Download Attachment: P1240714.JPG
1328.38?KB
Download Attachment: P1240715.JPG
1044.19?KB
Download Attachment: P1240716.JPG
1550.49?KB
Download Attachment: P1240717.JPG
1507.1?KB
View Profile
Oswego, NY
[#12] Posted: 04/17/2012 - 05:01:28 AM
Not bad. If you already bought metal corner bead for the outsides, take it back and get a roll of Strait Flex corner tape. It's a thick perforated paper tape made for outside corners. It's a little pricey but it's worth it.
If you smack a corner later on, you end up with a dent to fix instead of a wad of bent metal that's never going back where it was.
View Profile
[#13] Posted: 04/17/2012 - 05:43:46 AM
Metal bead already there...too late. Maybe next time.
Sanding is going well. I'm using flexible blocks to dress the corners and rough edges first. Then I'll switch to 220 grid style and smooth out the fields and blend everything in.
I thought about running a fine bead of paintable caulk down the inside corners for a fine smoothing touch. Anyone ever done this?
View Profile
[#14] Posted: 04/17/2012 - 07:55:37 AM
....ditch the caulk idea. I need to mix a tiny batch of spackle for fine touches and I'll just smear it in the corner with my finger. Probably wont even need to sand.
Olathe, KS
[#15] Posted: 04/17/2012 - 08:01:26 AM
I stopped my backer board short from the ceiling about 1/4", and running tile up to about 1/8" from the ceiling sheetrock, and using color matched caulking at the ceiling/tile joint to finish it off. It's made by the grout manufacturer.
Kevin Wattenbarger
Allied Home Inspections, Inc. Olathe, KS
"Helping You Understand Your Home's Health"
www.AlliedHomeInspections.com
www.911owned.com
View Profile
Eureka, CA
[#16] Posted: 04/20/2012 - 09:30:53 AM
I bought all my doors as solid seconds. Made all my jams. All the trim for my windows from rough opening to finish. Made all my moldings, which ended up being 3 piece. Made my own cabinets and counters excluding doors and drawers. Measured everything like 6 times. Bla, bla, bla. People come by and see it say, "Nice, have any beer".
Denny Waters
View Profile
Lafayette, Louisiana
[#17] Posted: 04/20/2012 - 11:19:49 AM
1328.38?KB
1044.19?KB
1550.49?KB
1507.1?KB
Is it common practice to put that many screws in the drywall?
Marc
View Profile
indy, IN
[#18] Posted: 04/20/2012 - 2:36:34 PM
[/quote]
Marc
[/quote]
our small remodel co. typically field screws @ 12" oc and butt joints @ 8". So, yes?
View Profile
[#19] Posted: 04/21/2012 - 12:43:40 AM
Whoever suggested using clothesline rope for tile spacers, thanks. It's a great idea. I'm using 3/16 nylon and it blows those little tile spacers out of the water. I cut the rope sections to about 8". I leave the bottom part protruding to make it easy to pull them out.
In other news, we had to deal with defective tub issues and some crafty thinking about the best way to level the floor. I'll be using a different size notched trowel in various areas under the hardie boards. I'll check again after that and might scratch in a few patches with thinset and a trowel before setting floor tiles.
Also, I realized too late that my tub alcove rough opening is 60 1/2" which is 1/4" too big. This posed problems with tile overlap at the tub lip. Rather than rip everything back out I decided to use a 1/2" notched trowel to spread thinset for the wall tiles. The added thickness makes up the difference just about perfect. When the mortar mix is just right, working with the heavy application is not too cumbersome.
Checkout the warped tub skirt. Also, the skirt hit the floor and the feet were still 1/4" off the floor. F'ed up!
Download Attachment: P1240723.JPG
1487.91 KB
Playing with various tile layouts.
Download Attachment: P1240725.JPG
958.98 KB
You can see the difference in the original floor mortar bed as much as 1/2" from one end to the other.
Download Attachment: P1240729.JPG
1557.98 KB
Taped in and setting tile.
Download Attachment: P1240743.JPG
1184.41 KB
Mortar bed with 1/2" notched trowel.
Download Attachment: P1240746.JPG
1094.38 KB
View Profile
Rochester, New York
[#20] Posted: 04/21/2012 - 04:25:44 AM
No water-proofing behind the enclosure tile?
Chad Fabry
StructureSmart Home Inspection Rochester, NY
www.structuresmart.com
View Profile
[#21] Posted: 04/21/2012 - 07:53:30 AM
Nothing that I can find in the Hardie documents even recommend, let alone require any additional waterproofing. A video at their site shows the stuff virtually impermeable to water.
I have the joints filled, taped and covered with thinset according to their instructions. The mortar bed will be 1/4" thick and I'll be sure to use grout sealer (and re-seal as recommended).
I suppose when it comes to good, better or best, I'm somewhere in the middle. Do you think it's going to fall apart or cause other problems?
View Profile
Oswego, NY
[#22] Posted: 04/21/2012 - 09:04:55 AM
Quote: I cut the rope sections to about 8". I leave the bottom part protruding to make it easy to pull them out.
No No No. Don't cut the rope into small pieces.
Let it run the entire length of the course. Then, you only have one to pull later. Jump it over the horizontals, where the vertical runs intersect.
Unless, you're staggering the pattern. In that case, you still leave the horizontals full length.
View Profile
Chicago, IL
[#23] Posted: 04/21/2012 - 1:01:12 PM
If you're not running a steam generator, you don't need waterproofing under the tile. If it's a steamer, you gotta have it.
Kurt in Chicago
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
