| Posted By |
Ridgewood, NJ Posts: 949
| offline |
Chicago, IL Posts: 9508
| offline |
Very old A/C system
[#2] Posted: 05/18/2012 - 7:56:01 PM |  | |
An old water system...(?)....
Kurt in Chicago
Gaston, Oregon Posts: 8092
| offline |
Very old A/C system
[#3] Posted: 05/18/2012 - 9:03:39 PM |  | |
It could have been a water source system or they could have just mislabeled the drain. Maybe they meant to write, "condensate drain."
| offline |
Lafayette, Louisiana Posts: 3859
| offline |
Very old A/C system
[#5] Posted: 05/19/2012 - 07:49:18 AM |  | |
Water systems don't use expansion valves and evaporative coolers evaporate water directly into the air.
My guess is an ammonia/water absorptive system which used a pump/heat source or a refrigerant compression system like nowadays.
Neither would explain the label.
Long time no see Terry.
Marc
| offline |
| offline |
Very old A/C system
[#7] Posted: 05/19/2012 - 09:15:38 AM |  | |
Ok. By 'water system', I though was meant either chiller-like systems that use water to distribute cooling loads or hot water heating systems that use a heat exchanger in the airflow.
Marc
Kenmore, WA Posts: 15397
| offline |
