Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
stucco corners
Previous Topic: Discoloration - Topic - Next Topic: CMUs with no mortar New TopicReply to TopicShare Topic
Posted By
corpus christi, tx
Currently offline offline
Thread Start First Page
[#1] Posted: 07/09/2012 - 09:07:26 AM
Some of the corners on my stucco house are strarting to rust. The house is only six months old.The builder said they did not use zinc on all the corners.Some corners they used a galvanized metal.he said they will come back and wrap the corners and everything will be fine. How do you wrap over stucco? is this a good idea?
View Profile
stucco corners
[#2] Posted: 07/09/2012 - 5:53:20 PM
I hope they are not using drywall corner bead for exterior stucco!
Scott Patterson
View Profile
Lafayette, Louisiana
stucco corners
[#3] Posted: 07/09/2012 - 7:43:38 PM
All lathe and weep screed should have been corrosion-resistant products.
I don't know what he means by 'wrap over' but it's not a solution if he's just going to cover it up.
I suggest that you hire an expert to detail every flaw in the entire stucco installation. Perhaps it's much worse than you believe it to be.
Marc
View Profile
Dallas, TX
stucco corners
[#4] Posted: 07/09/2012 - 10:57:57 PM
Reach out for Thom Walker at 361-774-7182.
He is a very good inspector in the Corpus Christi area.
Cheers,
Nolan E. Kienitz
Nolan's Inspections, LLC
Dallas Home Inspections
http://www.NolansInspections.com
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
