Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Plumbing Forum >
redundance
Previous Topic: Interesting flush mechanism - Topic - Next Topic: Code cite 4 painting plastic vent pipe above roof New TopicReply to TopicShare Topic
Posted By
View Profile
Severna Park, Maryland
Currently offline offline
Thread Start First Page
[#1] Posted: 07/13/2012 - 5:25:41 PM
Two active wells. The first time I've seen this. Have you ever seen two well setups in the same house? 1993 build.
Click to View
47.26 KB
Click to View
49.44 KB
Click to View
39.04 KB
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
View Profile
Sykesville, Maryland
redundance
[#2] Posted: 07/14/2012 - 05:15:40 AM
They might have had a flow problem - too few gallons per minute. Unusual set up, I've only see it twice, but I don't see anything wrong as long as you have both well caps/heads accessible.
"your home inspector shoulda seen that, hon."
View Profile
Collins, NY
redundance
[#3] Posted: 07/14/2012 - 06:37:55 AM
I built one that had two wells and still had recovery issues. We ended up with a 600 gallon holding tank and a timer arrangement with a high/low float override.
Tom
Dr Joe Lstiburek
View Profile
Linden, MI
redundance
[#4] Posted: 07/14/2012 - 07:15:08 AM
It's very common in an area of my county where the availability of ground water is very poor. At a depth where water in plentiful the water is too salty to use. The usable water is very shallow, about 20 or 30 feet deep, but it is basically surface runoff.
In order to get an adequate volume they have to drill two shallow wells separated from each other at different ends of the property.
Mark Mustola
ValueCheck Home Inspections
Linden, MI
www.ValueCheckInspections.com
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
