Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Foundation Systems Forum >
Support post
Previous Topic: Polyurethane Foam - Topic - Next Topic: Brick Piers New TopicReply to TopicShare Topic
Posted By
View Profile
Samantha, AL
Currently offline offline
Thread Start First Page
[#1] Posted: 07/24/2012 - 5:40:54 PM
Can any one tell me who may of made these posts? I could not find a label on them.
I need to look up and see if they are permanent post
I know we have talked about this type of post before and I will look up the tread about them later tonight.
Thanks for the help.
Click to View
66.35 KB
Click to View
66.26 KB
Click to View
63.83 KB
Have a good day inspecting.
Phillip R. Smith Sr.
Samantha (Tuscaloosa) AL
www.homesweethomeinspectionsal.com
"When you inspect crap, you find crap." Phillip 2010
"Always desire to learn something useful."
- Sophocles
View Profile
Lafayette, Louisiana
Support post
[#2] Posted: 07/24/2012 - 5:50:06 PM
Found this ASHI Reporter article from 2006 about adjustable steel columns.
Marc
View Profile
Evergreen Park (Chicago), IL
Support post
[#3] Posted: 07/24/2012 - 6:21:41 PM
If it's not stamped you won't know who made it. I contacted Tiger Brand jack posts many years ago. The rep told me their basic screw jack is designed for temporary or additional support, not as a primary support. If the top, bottom and screw are secured they work great and hold up tons and tons of weight.
Here's their link. You can call and talk to someone. That's what I did.
http://www.tigerbrandjackpost.com/
Mike Lamb
http://www.inspection2020.com/
View Profile
Chicago, IL
Support post
[#4] Posted: 07/24/2012 - 6:40:43 PM
Technically wrong, but probably just fine for a simple house.
Kurt in Chicago
View Profile
Wyckoff, NJ
Support post
[#5] Posted: 07/24/2012 - 7:00:18 PM
If the pin in the center of the column is not welded it can be knocked out with a hammer and now you have no support. How is that permanent?
We can't solve problems by using the same kind of thinking we used when we created them
Albert Einstein
View Profile
Support post
[#6] Posted: 07/24/2012 - 7:22:05 PM
Then don't do that then!
Marc
View Profile
Victoria, British Columbia
Support post
[#7] Posted: 07/24/2012 - 8:20:16 PM
I have read, possibly right here, that the permanent posts will have welded ends, not just pressed or crimped together.
Permanent posts will be heavy gauge steel.
Also when installed, the threaded rod should be welded to the nut so it can't be turned.
If none of the above, you got temporary jack posts. Easy one.
www.allsafehome.ca
View Profile
Chicago, IL
Support post
[#8] Posted: 07/24/2012 - 8:45:44 PM
They're definitely temporary posts. No question.
It boils down to "how bad is it really?".......
My experience, in a simple house, is not bad.
Kurt in Chicago
Walpole, MA
Support post
[#9] Posted: 07/25/2012 - 03:42:06 AM
I just shoot from the hip.. 'these are very strong, but temporary... replace them with permanent supports'... and move on.. I don't linger on it... If they asked why they were used, I simply say "I don't know'..
If your car could travel at the speed of light, would your headlights work? (S. Wright-Boston Area Philosopher)
View Profile
Samantha, AL
Support post
[#10] Posted: 07/25/2012 - 06:30:27 AM
You can tell that the basement area was re-done.
There is about 12 of these posts. I am going to write it up and they (owners) can have someone else bless it.
Thanks for everyones input.
- Sophocles
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
