Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
Help with cracked brick on duplex (pictures)
Previous Topic: Architectural Name - Topic - Next Topic: What is this stone? New TopicReply to TopicShare Topic
Posted By
Bourbonnais, Illinois
Currently offline offline
Thread Start First Page
[#1] Posted: 08/25/2013 - 7:56:41 PM
Hello,
The duplex is a small ranch with all brick. Built in 1979. Walking around the outside I noticed several cracks. Most seem to be coming from the corner of a window all the way to the ground. Cracks aren't big, but there's are at least 5 around the entire duplex.
Any input would be great.
Thanks!
Click to View
70.66 KB
Click to View
65.94 KB
Click to View
81.58 KB
Click to View
90.62 KB
Click to View
90.62 KB
Click to View
72.58 KB
Click to View
121.34 KB
Click to View
124.78 KB
Click to View
136.95 KB
View Profile
Administrator
Chicago, IL
[#2] Posted: 08/25/2013 - 8:07:26 PM
Just a quick guess, but those drop sills (same width as opening, as opposed to lug sills that extend past the opening) let water into the wall....water in the brick could be freezing and causing some of the movement that's cracking the brick.
Or, there's incremental settlement in the foundation/footing and you're seeing it in the veneer. Are there any foundation cracks in the basement indicating movement?
Show us some establishing shots; a bunch of close ups isn't showing the whole story. Patio cracks are not likely related to the "problem", but they could be...show us an establishing shot of the effected area.
Also, Great Stuff/Crazy Foam is not masonry repair material; dig it out and repair the joints with mortar.
View Profile
Senior Member
Victoria, British Columbia
[#3] Posted: 08/25/2013 - 8:55:46 PM
Yes, the repairs look worse than the cracks do.
The crack above the crawlspace vent Pic 2 is interesting, because it changes direction. I would be inclined to think it is minor cracking of the veneer. We don't know what is behind the brick veneer, but it could be wood frame. If so, some cracks of that type would be normal, caused by some minor settlement.
View Profile
Senior Member
Lafayette, Louisiana
[#4] Posted: 08/26/2013 - 05:04:31 AM
Normal? Ain't nothing normal about it.
Marc
View Profile
Senior Member
Collins, NY
[#5] Posted: 08/26/2013 - 05:18:43 AM
It's a rambling ranch set up as a double. I bet it's over 100' long. The veneer has room to expand above the rowlocks but not below them. There should have been expansion joints every 25 to 30 feet.
View Profile
Administrator
Chicago, IL
[#6] Posted: 08/26/2013 - 05:47:34 AM
Marc
Looks normal to me. Raymond's explanation is probably as close as any of our guesses. Unless there's something we can't see in the foundation, looks like the normal crappy (no flashing, no expansion joints) brick veneer job to me.
View Profile
Senior Member
Little Rock, AR
[#7] Posted: 08/26/2013 - 06:24:30 AM
The texture of that brick looks odd. Are they possibly concrete? If so, it's definitely more susceptible to expansion/contraction cracking. A little of that was sold around here in the 90's. Masons hated it since you had to place a lot of expansion joints to minimize cracking.
View Profile
Senior Member
[#8] Posted: 08/26/2013 - 06:36:45 AM
Marc
Different semantics. I don't tell any client that brick veneer cracks that bad is 'normal'.
I can understand how 'normal' could be taken in a different way on this forum.
Marc
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
