Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Structural Forum >
Todays deck
Previous Topic: Posts on porch - Topic - Next Topic: Triple Top Plates New TopicReply to TopicShare Topic
Posted By
View Profile
Samantha, AL
Currently offline offline
Thread Start First Page
[#1] Posted: 08/01/2007 - 1:47:08 PM
Can anyone give me a back-able reason why landscape timber cannot be used as support post?
Image Insert:
146.72 KB
Image Insert:
112 KB
Image Insert:
79.18 KB
Yes there are other items wrong with the deck.
Any comments are welcome.
Have a good day inspecting.
Phillip R. Smith Sr.
Samantha (Tuscaloosa) AL
www.homesweethomeinspectionsal.com
"When you inspect crap, you find crap." Phillip 2010
"Always desire to learn something useful."
- Sophocles
View Profile
Gaston, Oregon
Todays deck
[#2] Posted: 08/01/2007 - 2:12:34 PM
Every piece of load-bearing lumber in a house is supposed to have a grade mark on it. Did this?
A piece of wood in this location is supposed to be pressure-treated *and* bear a bear a quality mark for the pressure treatment.
The lumber dimension also has to comply with those in the code tables. That looks like an odd size.
- Jim Katen, Oregon
Jim Katen, Oregon
www.amipdx.com
View Profile
Samantha, AL
Todays deck
[#3] Posted: 08/01/2007 - 2:39:08 PM
Jim,
No and No
Here are the size of the post
Image Insert:
126.57 KB
Image Insert:
138.99 KB
- Sophocles
View Profile
chicago, il
Todays deck
[#4] Posted: 08/01/2007 - 3:14:31 PM
Nice ledger support.
Is there even an L bracket where that timber is sitting?
Just one little kick should lead to loads of laughs.
Bob.E
owner operated consumer protection
http://chicagopropertyinspection.com/
View Profile
Columbus, Mississippi
Todays deck
[#5] Posted: 08/01/2007 - 5:51:17 PM
As far as I know they're rated for "outdoor use", but not "ground contact". I'm not sure if that makes them officially "treated" or not.
I hate those landscape timbers. I find them used in contact with the ground all the time, often as a substitute for the slightly more expensive honest-to-goodness treated 4 x 4.
They are a bit odd, being rounded on two sides. I've long thought they had less beef than a real 4 x 4, but I haven't checked up on it.
Brian G.
Anything to Save a Buck
www.accuspecllc.com
View Profile
Severna Park, Maryland
Todays deck
[#6] Posted: 08/01/2007 - 5:56:30 PM
I see it sitting on the concrete block wall but is it actually anchored in any way?
John Dirks Jr - Arundel Home Inspection LLC - MD license: 29827
Maryland Home Inspectors - Maryland Home Inspection - Maryland Radon Testing - Baltimore County Rental Inspection
View Profile
Gaston, Oregon
Todays deck
[#7] Posted: 08/01/2007 - 6:54:41 PM
Quote: Originally posted by Brian G.
[navy]As far as I know they're rated for "outdoor use", but not "ground contact". I'm not sure if that makes them officially "treated" or not.
The ones up here have no marking on the wood at all. Certainly they're treated with some amount of some chemical. But what it is and how much is there is a mystery. That's fine if you're going to use them as a border for your garden, but it won't do if you're supporting a structure with them.
Quote: [navy]They are a bit odd, being rounded on two sides. I've long thought they had less beef than a real 4 x 4, but I haven't checked up on it.
Without a species and grade stamp, no one knows. That's why those marks are required.
- Jim Katen, Oregon
Jim Katen, Oregon
www.amipdx.com
View Profile
Samantha, AL
Todays deck
[#8] Posted: 08/01/2007 - 8:05:33 PM
Jim,
Thanks for the info, That just what I needed.
- Sophocles
View Profile
Samantha, AL
Todays deck
[#9] Posted: 08/02/2007 - 04:36:50 AM
John,
No it was not.
- Sophocles
View Profile
Todays deck
[#10] Posted: 08/02/2007 - 07:08:25 AM
Good, I can use that. What's the reference for that? Is it in the IRC somewhere?
Brian G.
Another Bullet in My Gun
www.accuspecllc.com
View Profile
Albany, NY
Todays deck
[#11] Posted: 08/02/2007 - 09:57:26 AM
In 2000 IRC see §R404.2.1 for required grade marks on all load bearing lumber. For markings on wood that needs protection from decay, see §R323.2.
View Profile
Gaston, Oregon
Todays deck
[#12] Posted: 08/02/2007 - 8:53:43 PM
I think that last one should be 319.2
- Jim Katen, Oregon
Jim Katen, Oregon
www.amipdx.com
View Profile
Comer, GA
Todays deck
[#13] Posted: 08/03/2007 - 7:27:54 PM
Those landscape timbers fool lots of DIYers. They are not grade stamped nor treated to any standard, but they are really cheap. Near my home is a big plant where they peel off wood fibers to make oriented or parallel strand beams. One of their by-products are these little 3-inch spindles that are hauled out of there by big truck-loads. Treat them heavily enough and you get a good fence post. Dress them two sides and dip thru a green bath and you get "landscape timber". The name is the giveaway, they're not listed for use in buildings, period.
"Emancipate yourself from mental slavery, for only ourselves can free our minds"-Bob Marley
View Profile
Todays deck
[#14] Posted: 08/04/2007 - 03:23:42 AM
I am glad this post was started. I was under the impression that the only difference was cosmetic but now I know better.
View Profile
Albany, NY
Todays deck
[#15] Posted: 08/11/2007 - 08:07:14 AM
- Jim Katen, Oregon
I think you are correct, Jim. NY is currently moving from a code based on the 2000 IRC to one based on the 2003 IRC. I have the 2000 on CD to do quick key word searches and to copy & paste, but I haven't yet purchased the electronic version of the 2003. I just checked my paper 2003 IRC and the section I was referencing was moved to 319.2.
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
