Username:
Password:
Save Password
Join TIJ Forums
Lost Password?
Subscribe to TIJ's Newsletter
All Forums > Technical Forums > Structural Forum >
Another POS house
Previous Topic: Engineered rafters - Topic - Next Topic: Posts on porch New TopicReply to TopicShare Topic
Posted By
View Profile
Gervais, Oregon
Currently offline offline
Thread Start First Page
[#1] Posted: 08/13/2007 - 09:02:54 AM
Originally built in 1950 with several additions. Floor drops, I kid you not, at least 6" from the front to the rear. Floors also slope to the middle dropping about 3". Hip roof with deformations in the planes that correspond to changes in framing. Lots of uneven and mixed construction.
What I think happend was that the original front portion of house sagged to the original chimney and they never jacked the house back up when they started adding on to it so they continued the mess until they ended up with a 6" drop at the back.
Although the framing is all uneven it's obvious someone went down into the crawlspace and added beams to provide additional support.
The framing and foundation system is so mixed up I can't tell from a visual inspection whats OK and whats not OK without trying to draw up a framing plan to try and do a first order analysis clearly something beyond what I contracted to do.
In cases like this where everything is out of level but appears to be (theres that weaselly phrase again) supported what do I tell the client to do? Call in an structural engineer to figure it out?
"Hire a carpenter working under the guidance of a structural engineer to repair and relevel the floor " Something like that?
Chris, Oregon
View Profile
Kenmore, WA
Another POS house
[#2] Posted: 08/13/2007 - 09:14:59 AM
I'd say something like, "The framing under this house is such a cobbled-together mess that, even if I had all day, I don't think I could properly evaluate it for you. You're going to need to have a professional engineer examine the sub-structure of this home to determine what corrections, if any, can be made effectively. Once you have the PE's report, contact some reputable contractors to find out what the PE's recommended fixes are going to cost you."
OT - OF!!!
M.
View Profile
Chicago, IL
Another POS house
[#3] Posted: 08/13/2007 - 09:45:52 AM
Leveling a floor that's 6" out isn't usually possible without gutting the house, at least not in my experience.
When you start pumping the 50 ton jacks to level a floor, you blow the whole place to hell and back; plaster blows off walls, framing explodes, etc.
I remember my first experience w/this. I was about 14, down in the crawlspace w/a half dozen 50 ton hydraulics, and we thought we'd just level the DR floor by pushing it back up to level. We started pumping away slowly, things seemed like they were moving, then we heard something that sounded like someone tossed a grenade.
Plaster had blown off the bearing wall all the way across the room & hit the exterior wall (about 14'); if anyone had been standing there, they'd have been creamed.
The bearing wall studs had simply exploded outward; the floor never really got level. Maybe we got it up 3/4", but that's about it. When it takes several decades for something to "flow" into position, it's not going back in a weekend.
Kurt in Chicago
View Profile
Jefferson Twp., NJ
Another POS house
[#4] Posted: 08/13/2007 - 3:56:08 PM
Kurt is right on target here.
I remember a house years ago. Built in the 20's, second story floor joists for two large rooms converged and sat on a wall that had an 8' opening between it's two rooms on the first floor. Due to the upstairs floor doing a funnel impression we pull of the plaster on the downstairs to see that the header is comprised of two 2x4's turned flat (gotta love it). The 3) 2x12's we used as a temp. header to jack under only hit the middle three joists, the ends were over 4" low... Pushing everything back up was done over 3-4 weeks... Bout a 1/2" or less every few days then let it settle in. In the end there was still about an inch of space between the ends of the header and the last joists. That was all she would go and we shimmed the rest. Six inches of settling? Now thats a project.
Kyle Kubs
Benchmark Home Inspection Services
New Jersey NJ
View Profile
Kenmore, WA
Another POS house
[#5] Posted: 08/13/2007 - 6:44:18 PM
Somewhere in here is a story about a floor that my brother and I had to flatten in 1973 in a 150 year old house. You can probably find the article if you word-search the site for Hughie. Ever since then, I always warn folks about trying to jack up and flatten floors.
ONE TEAM - ONE FIGHT!!!
Mike
View Profile
Gervais, Oregon
Another POS house
[#6] Posted: 08/13/2007 - 9:55:59 PM
So concerns about trying to flatten a floor in a house are more tricky then raising an already sound house off of its foundation?
It sounds like deformations by themselves don't justify correction just because they are out of plumb. There has to be an underlying concern that whatever has caused the deformation might still be active?
So if you see a 2" slope in the floor to the middle of a house lets say and you can see new work that satisfactorily supports the floor then report what your see but you wouldn't recommend that the floor be necessarily flattened ?
When if ever would you recommend flattening a floor that is otherwise properly supported?
Chris, Oregon
View Profile
Gaston, Oregon
Another POS house
[#7] Posted: 08/14/2007 - 01:12:49 AM
Quote: Originally posted by Chris Bernhardt
. . . In cases like this where everything is out of level but appears to be (theres that weaselly phrase again) supported what do I tell the client to do? Call in an structural engineer to figure it out?
Chris, Oregon
If it's bad enough, yes, I'll call for a PE. Otherwise, I'll just recommend a good contractor.
When I find myself inspecting places like this, it's a sign that I need to raise my prices.
Oh, yes, I also agree that trying to jack up a mess like this will just make a bigger mess. Out here in Gaston several years ago, two brothers tried to straighten out such a house. One was under the house adjusting the jacks while the other was up top yelling directions. The whole house shifted sideways and landed on the brother in the crawlspace. It took some quick chainsaw work to get him out whereupon he grabbed a 2x4 and attacked the up-top brother. Fortunately, his cracked ribs and punctured lung prevented him from doing any real harm to his sibling.
Gaston, what a great town.
- Jim Katen, Oregon
Jim Katen, Oregon
www.amipdx.com
View Profile
Chicago, IL
Another POS house
[#8] Posted: 08/14/2007 - 04:55:22 AM
Chris, Oregon
Don't think I would. Never have. I tell 'em that it's settled, figure out why, figure out if the new supports will keep it from going anywhere further, and that's it.
Kurt in Chicago
View Profile
Boston, Mass.
Another POS house
[#9] Posted: 08/14/2007 - 10:33:21 AM
1950s house across the street from me sank/tilted about 8".Bean bag realtor lady had kids jack the back of the house to level. Broke most of the windows-could not get the doors to work. Chimney sprang off of the house--Fire Chief condemned. Came down the next day.
Real contractors came in and "fixed" the house. Took them 3 weeks-new windows/doors and new chimney/fireplace and more?
I confined my laughter to my cellar office behind two closed doors. That was 25 years ago-still brings a smile to this old inspector boy.
Jack Ahern Boston on the Charles and Bridgton,Maine
Member ASHI
Jump To:
Go To Top Of Page
Pick an RSS Feed
Find a Home Inspector
Powered By: Snitz Forums 2000
