Konrad Posted June 22, 2004 Report Share Posted June 22, 2004 I'm a little unclear about the hearth requirements for gas inserts. IRC appears to defualt to the manufacturer's listed installation requirements. The Code Check flip book (HVAC) calls out 16" for gas inserts. Is there an industry standard, or have I misread the IRC? Quote Link to comment Share on other sites More sharing options...
crusty Posted June 22, 2004 Report Share Posted June 22, 2004 It would depend on whether you are referring to a gas insert or a gas appliance installed in the fireplace. For a gas insert, manufacturer's specs would rule for a listed insert. Non listed would default to code requirements. If it is simply a gas appliance installed in the fireplace I believe standard fireplace hearth extension requirements would need to be upheld. Quote Link to comment Share on other sites More sharing options...
