Bill Kibbel Posted August 13, 2009 Report Posted August 13, 2009 Please check out my latest "old house" post. The more people that see it, the happier it makes my bosses at oldhouseweb.com. Gas Lighting - Beyond the City
gtblum Posted August 13, 2009 Report Posted August 13, 2009 I might become a regular reader. That was good.
Michael Carson Posted August 18, 2009 Report Posted August 18, 2009 I too enjoyed the article and will become a reader. Interesting info on the headlights.
Bain Posted August 18, 2009 Report Posted August 18, 2009 I read this last week when you started the thread, Bill. Very cool. My only suggestion would be to make the graphic higher-rez and clickable. Even when I expanded the schematic 400% via Explorer, the labeling of the individual parts was difficult to read.
Bill Kibbel Posted October 26, 2009 Author Report Posted October 26, 2009 My only suggestion would be to make the graphic higher-rez and clickable. Even when I expanded the schematic 400% via Explorer, the labeling of the individual parts was difficult to read. This is the best that I can get it.Click to Enlarge 687.85 KB I also happened across this recently: THE STORY OF ACETYLENE AS TOLD IN QUESTIONS AND ANSWERS. Ãâ©1900
Brad Manor Posted October 26, 2009 Report Posted October 26, 2009 I "follow" Oldhouseweb on Twitter and am a "fan" on Facebook - both venues give me a heads up whenever there is a new article posted. -B
Terence McCann Posted October 26, 2009 Report Posted October 26, 2009 Hey Bill, a question regarding that article: Anyone who has used Oxy- Acetylene for brazing etc. knows how dirty Acetylene burns on its own. How did they get around this or did they?
Tom Raymond Posted October 26, 2009 Report Posted October 26, 2009 Was acetylene used for space heaters? My old house (1870) was plumbed for gas in every room, including a tap for a space heater and one for a light, apparently added after the building had been up for some time as there were access holes cut through upper floor boards. I have removed all of the gas lines from the second floor, and all the lighting and space heating branches on the first floor, but most of the gas pipe in the basement is original, including a few valves. Tom
Bill Kibbel Posted October 26, 2009 Author Report Posted October 26, 2009 Hey Bill, a question regarding that article: Anyone who has used Oxy- Acetylene for brazing etc. knows how dirty Acetylene burns on its own. How did they get around this or did they? I don't have much experience with burning acetylene, except playing around with an old miners head-lamp and a bicycle lamp. From what I've read though, the carbon produced seemed to be more of a problem on the burner tip openings, which required regular cleaning. The tips for lighting, versus the burners for torches, were likely quite different. Also, consider what other fuels for lighting were available at that time, for comparison. Kerosene and sometimes gasoline were used where "city gas" wasn't available. In cities and larger towns, that had gas works and distribution piping, the gas was usually "coal gas". The burners and lamps available at the time with these fuels also burned pretty "dirty".
Bill Kibbel Posted October 27, 2009 Author Report Posted October 27, 2009 Was acetylene used for space heaters? My old house (1870) was plumbed for gas in every room, including a tap for a space heater and one for a light, apparently added after the building had been up for some time as there were access holes cut through upper floor boards. I have removed all of the gas lines from the second floor, and all the lighting and space heating branches on the first floor, but most of the gas pipe in the basement is original, including a few valves. Tom Burning acetylene for for illumination was cost-effective. For heating, it's not. When burning acetylene for illumination, with only surrounding oxygen present, a brilliant, steady white light is produced. Long after electricity was readily available, acetylene lighting and projectors were still preferred in theatres. For any decent heat output, additional oxygen needs to be mixed with the acetylene. Each pound of acetylene burned would require about 28 cu. ft. of pure oxygen. The cost to produce, transport and store that volume made it a poor choice for heating. There were also concerns that burning that ratio would produce tremendous amounts of carbonic acid (H2CO3). What you describe is much more likely for the distribution of "city gas".
Tom Raymond Posted October 27, 2009 Report Posted October 27, 2009 I suspected as much. That actually helps me to age the gas system as the other "old" houses on my street are at least 50 years newer than mine. Interesting that indoor plumbing came before a public heat and light utility, when I bought the house it had the original septic system with 1896 on both the cast iron tank lids. Tom
Bain Posted October 27, 2009 Report Posted October 27, 2009 My only suggestion would be to make the graphic higher-rez and clickable. Even when I expanded the schematic 400% via Explorer, the labeling of the individual parts was difficult to read. This is the best that I can get it.Click to Enlarge 687.85 KB I also happened across this recently: THE STORY OF ACETYLENE AS TOLD IN QUESTIONS AND ANSWERS. Ãâ©1900 It was the slightest bit fuzzy--in part due to the old-style font--but I could read every word. It's likely that only the geeksters like us would take the time to read the schematics and try to understand them, but it's nice when they're legible. It's sort of like the Scully nozzle in another post of yours tonight. Its actual name isn't really that important, but I knew what it was 'cause I took the time to read some other schematic several years ago.
