Thanks in advance for your help! During driving rain in a specific direction, I get water entering my basement. It appears to be coming into the front wall of the house, running down the wall, and then hitting the top off my basement wall and running down into the basement. The wall in question is brick veneer and has one window on the second story (first story is covered by a garage). Upon looking at the wall, I noticed cracks in the caulking around the window. I took a hose and sprayed water all around and on the window for a while and was able to reproduce the problem. Now, I have no problem resealing the window with new caulk, but here are my questions/concerns: 1/ The house is relatively new and the caulking is already badly cracked. I worried this may be due to the width of the gap being caulked. It seems VERY wide. Is there a minimum standard for the space to be caulked around a window? 2/ Assuming water was able to penetrate the caulk, should there not be some sort of window/sil flashing to direct the water back out? 3/ Assuming water penetrated the caulk, and there was no window flashing, and the water enters the wall. Should the through-wall flashing of the brick veneer not catch this water and direct it back out via weepholes? Does it seem normal to have the ater run all the way down into my basement? Thanks.
