I bought a new Grundfos 15-50 pump on Ebay for my hot water circulating loop. Plumbed it in, got water in the system, turned it on. Didn't start. Tried all 3 speed settings, wouldn't start. I removed it, and checked that the voltage is getting to the pump. It is. So I took the impeller cover off, and (this is done with the impeller wet) with the cover off, it spins beautifully, and if power is applied (just for a second), it starts and turns perfectly. But when I put the cover on, it binds up and won't turn. All I did was remove the cover. I didn't touch the gasket. Spins without the cover on, won't spin with the cover on. I can't take it back because it came from a private seller on Ebay, bought it months ago. And yes, I'm installing it with the shaft horizontal. Any suggestions would be much appreciated. Peter.
