james prosise
james prosise's Achievements
  1. What are the consequences of not insalling the green grounding screw from the grounding bar to the breaker box? Electrolysis?
  2. My neighbors breaker box in his home does not have the green screw connecting the grounding bar to the box itself. This is a new home and he wants to know if this will cause a problem. What are the possible consequences? electrolysis?
  3. I have a 8 year old frame home. Two of the bedrooms are on the same breaker. The bedrooms four aluminum window frames have 18-20 volts a/c. When I turn the breaker off, the voltage goes away. My question is this, "is this a problem that can be traced and fixed without tearing out the sheetrock on all the walls". Help, not sleeping very well....Any ideas on what the problem is? The siding is hardy board with no conductive material. The voltage was taken with a digital volt meter. The walls are stud/plywood/rolled felt/hardy board type of material, nothing conductive. That is what is driving me nuts. No foil etc..TV is fine.
