rickm
    2
rickm's Achievements
  1. zinco breakers are junk. they are guarentied not to trip even when the house is on fire and they where probably the cause. i have seen so many problems with the alum bus that i will not repair them any more !!!! the only thing to do with a zincvo box is to trash can it and start from new. ps save the breakers and sell them to the idiot that thinks that 1500$ dollars is to much to cave his house from burning down.
  2. i have a fun one. 200 amp service panel feed undergroud from a pole 150 feet away. 100 amp sub panel mounted on the feeder pole, and a detached shop feed from the 100 amp sub panel. the only grounding currently is a ufer at the service panel"i dont trust ufers". The way i read nec i need a ground rod at the service, a rod at the pole for the sub, and a rod at the shop sub for the building. and do not need to pull a ground between these three points
