I have just discovered that a window in my parent's house has been leaking for years. It has gotten to the point that the drywall under the Window has started splitting and the paint peeling. I didn't discover this until I moved a piece of furniture and saw it. When I questioned them about it, they said they noticed it a few years ago. With that said, I am going to have to assume that there is a nice biology experiment going on behind that wall even though there is no smell or visible mold/mildew evidence on the interior walls. They have also been complaining about little bugs called Springtails being found on the upstairs bedroom wall that is right above this leaking window. When examining the window I saw that there were quite a few of these bugs evident around the cracks in the window moulding and drywall. As these critters like damp places and live off fungus, I guess this is where the nest is located. I obviously need to fix the window leak, but at the same time will need to open the wall to find the leak. This will then expose the house to whatever is lurking (mold, bugs, etc) back there. I also assume that once I fix the leak, I need to open up the wall and let it dry out completely before sealing it back up? Can anyone provide some advise on the best way of tackling this so that the mold is contained? Do I contact a mold remediation service first, before fixing the windows? Do I fix the window and then bring in a mold remediation company? If there is mold, do I assume I will need to remove all drywall that even looks compromised until I see no evidence of mold, throw it out, let it dry, reinsulate, and seal it back up? When using a moisture meter, there is only one little area that is showing high moisture. Is it possible that it has not spread all over the place in there? Any suggestions and advice?
