Thanks Steve, Chad & Everyone!!! I agreed with you Chad. I definitely will be running design past an architect to confirm structral load capacities, as well as other building code requirements. You mentioned, "I would suggest packing down the framing to provide the space for at least six inches of insulation with foam chases to provide air circulation between the vented soffits and ridge vent." I am not sure what you mean by, "packing down". I am considering adding depth to some of the rafters that may need more space for adequate amounts of insulation. Would it make sense to use the 2x2's running up the rafters, with a high quality 2" rigid foam panel, well-sealed, and then fiberglass insulation to fill the rest of the space, and then the the foil-faced rigid that Chad recommends to overlay across the ceiling? Would I put the vapor barrier/retarder underneath the foil-faced rigid, or as the last layer underneath drywall? And finally, The Icyene option looks neat, but wouldn't that defeat my hopes of putting in my own sweat equity/labor? That looks like a dealer/distributor/installer-only option from what I have read. Thanks for helping the mere novice with your sage wisdom! - David
