Gas line running to the fireplace looks pro, doped connections, well-supported (I've seen amateur gas lines held up by wire coat hangers a few too many times). I would have probably run 3/4" instead of 1/2" - but the system only has a range and a water heater on it and it's a small house... so it's not like there are lines being run 60' out anyway. Venting is framed through the wall, a little sloppy, but has all the proper components and clearances (double checked before even thinking of turning the thing on). It's weird. Inlet pressure is fine, pilot runs strong, just a high outlet pressure and tiny blue flames at the burner.
