earthwindfire
    7
Everything posted by earthwindfire
  1. Unfortunately they were bought out a few years ago and the models are different and some parts are discontinued. Not much help there. I'm going to call a specialist tomorrow and get to the bottom of it once and for all.
  2. hah yeah makes sense this is what it looked like when it's running - logs are in like the manual says... hard to see the flames, but they're just about 2" tall and blue here's a close up of the front of the valve too Click to Enlarge 23.4 KB Click to Enlarge 40.22 KB
  3. Gas line running to the fireplace looks pro, doped connections, well-supported (I've seen amateur gas lines held up by wire coat hangers a few too many times). I would have probably run 3/4" instead of 1/2" - but the system only has a range and a water heater on it and it's a small house... so it's not like there are lines being run 60' out anyway. Venting is framed through the wall, a little sloppy, but has all the proper components and clearances (double checked before even thinking of turning the thing on). It's weird. Inlet pressure is fine, pilot runs strong, just a high outlet pressure and tiny blue flames at the burner.
  4. Other thought was that it was a volume issue, but that wouldn't cause the high outlet pressure anyway...
  5. Thanks for the photo tip - should show now... that's the bottom of the valve. I've seen stoves converted for propane that have the telltale red screw on the high/low adjustment knob... but this one doesn't have anything obvious if it has been converted.
  6. Ah yeah - good point about the orifice size. Seem like they could be large enough to be NG... I know propane is smaller but honestly I've almost never dealt with LP in my area so I'm not 100% on that. Click to Enlarge 113.4 KB Flame is strong at the pilot.
  7. Just bought a foreclosed house with a natural gas fireplace installed - looks like it's the vermont castings radiance RDV40... maybe 5-7 years old from what I can tell... Tried to start it up and the pilot lights fine, but the burner flames are quite small. Ran a manometer and the inlet pressure is right at about 10" WC but the burner pressure is too high at about 7-8" WC (should be 3.5). Those pressures seem about right for LP but not NG... did the previous owner foolishly install an LP stove on a NG line? There are no markings/stickers that say it's been converted to propane, but there is a red line in marker on the bottom of the valve... see photo So is that my problem? or is it just a broken valve/regulator? Double checked the venting and everything seems fine... the only problem seems to be the pressure at the burner. I might just get a technician out here, but I'd like to know if I'm completely screwed before I pay someone to come out ? it's getting cold! Click to Enlarge 61.53 KB
