Gauss44
    4
Gauss44's Achievements
  1. Yes, I live in an attic. The idea of pressurizing it with fresh air might work, although I'm not sure what an HRV is?
  2. What about gently pressurizing the interior of the apartment with fresh air? I'm thinking an HRV with adjustable dampers to yield slight pressurization.
  3. What about gently pressurizing the interior of the apartment with fresh air? I'm thinking an HRV with adjustable dampers to yield slight pressurization.
  4. I just moved into an attic apartment and whenever the temperature outside gets to be hot, 85+ degrees or so, my apartment starts reeking of TAR. Any ideas about how to fix this problem, or what will be required to fix this problem? I suspect the TAR odor is coming from the roof tiles. Maybe a can of air between the attic ceiling and roof would do? I'm also home most of the time and require air conditioning for a medical condition so ventilating this place will get to be expensive. Any suggestions regarding that? Thanks in advance if you can help!
