Sorry..the description is in a post earlier up, This is long winded ? I know ? but I wanted to see if could add clarification for Jim as he was kind enough to answer my question. I am in a fairly new home ( 2 years old ) and I wanted to wire in a portable generator ? one that I already have?not big enough to run AC or anything but it can certainly handle the fridge, freezer and some lighting. When I had the house built, I had the builder run a dedicated circuit to the outside of the house ( 50A breaker, 8 AWG, terminated in an outdoor rated junction box) for a future pool. SO basically Oddly enough when the pool builder wired everything they went directly into the panel so I have a spare circuit available, cable run through the walls, terminated on the outside of my home.I plan on using this to connect through to my main panel. This spare circuit however is in my sub panel?meaning I can not use the mechanical interlock between the mains breaker and the generator breaker. My plan to fix this is to disconnect the cable of this spare circuit ( which is in my sub panel), join it and run it over to the main panel ( panels are side by side) . Once I move the breaker to the new location I can use the proper mechanical interlock to ensure I don?t power the gen set while the mains are on. My question ? which hopefully is answered now is how to best make a connection with 8 AWG wire in my sub panel? And to be honest ? I actually think its 6 AWG wire that is installed not 8. I?m certain I can use a wire nut ? though I question the effectiveness of twisting 6 or 8 awg with a wire nut. Some other sites suggested using a split bolt connector but that looks like a bulky ( and to me unprofessional) way to join the wires. I think the cleanest way is using the splicer block that I have ? and with the model I have ? there is a cover so it will be clean and safe. I thank you for the answer and if any of the description here changes the answer ? please let me know. I may post a picture when done..for any one out there like me who likes to see final results. Appreciate all of the replies. Mac
