I am planning on installing ?? hardwood floors in my single level home with basement. The hardwoods will be installed above the basement level. As part of my preparations I have been taking moisture readings. The moisture content of the 1/2" plywood subfloor is mostly 8%. However along a certain exterior wall I have had readings much higher 13-18%. The partcleboard I removed along these exterior walls was not wet. Just outside this specific wall a deck ties into the house. Please see the attached sketch. Note the floor joist run continuously from inside the basement to outside underneath the deck. The exterior edge of the subfloor is exposed to the outside. What would you do reduce the moisture seen inside the house?
