nodrog
    Canada
nodrog's Achievements
  1. Fairly acutely I have developed asthma type symptoms BUT only in my house and they are worse the closer I am to the basement. In hunting for a problem (we thought it was a new sofa ....) we discovered a pretty bad mold problem in the basement. We had 2 companies out to do bids (both well thought of) 1 much less expensive and conservative. We went with them. They took out the moldy and wet areas in both affected areas of the basement and did the usual remediation stuff. All drywall was removed in affected areas. Sprayed, cleaned scraped etc. I was out of town for about a week and returned ... and I still have all of the same symptoms. They are doing an air test (but I am pretty skeptical of the value of this given what I have read on the internet). Some questions for the group: 1) There is clear water damage on the laminate floor - one of the mold companies wanted to pull up the laminate - the other did not. Any way to tell if there is mold uynder laminate without pulling it up? 2) One of the door frames is swollen a bit with water damage but no obv mold - should that have been remediated? 3) We had the mold crew back out and they reviewed their work and the rest of the basement and do not see anything else that needs to be remediated - as I said they are doing an air test. 4) We also havea dehumidifier and have had the ducts professionally cleaned. Any other thoughts? Seriously having to consider moving ... Thanks, G
