1: There was a water issue in the past. the gutters were bad and the sidewalk grade was incorrectly sloped. (these issues have been fixed and I have not seen any visible water/leaks/dripping in the basement for a good 6 months now.) 2: Someone stated they smelled musty/moldy odor on fabrics, etc witch prompted me to get it looked at tested. 3: Americas best clean and restoration came out and did an air quality test (on the main home level, as that is where we spend most our time, as they are certain mold is in the basement, made sense to test where we live mostly for health reasons) 4: They sent the air test to an outside laboratory and came back with elevated mold spores of Penicillium and Stachbotrys (witch is apparently a pretty bad one.) 5: They looked over the basement and said more then likely is mold behind the drywall, baseboards, etc. and he (with his hand) broke off a chunk of the loose, sandy crumbly debris that looks like it is layering the foundation stones and the smell of that material was very musty, odor, mildew smell to it. Since the air quality test came back the way it did, they think possibly of mold growth under the carpets, etc as one there is a mold problem it usually on get worse. 6: I have a 5 year old daughter and health issues with molds causing some major health issues is concerning so I want this fully corrected. 7: They also suggested cleaning and HEPA filtering the furnace vents and ductwork as mold spores possibly are getting transferred around through the HVAC system. That's pretty much the story in #'d points. hope this helps a little bit and im mostly trying to figure out the scrapping of the foundation walls as that definitely needs to be done based on the smell of that piece he showed me. I just don't want the foundation stone underneath or anything to be compromised. Thank you for your help
