This question mainly concerns rafter ties on a new construction design for a 9 in 12 roof, 60 psf snow load requirement. The footprint of the house is roughly 100 X 33, slightly less wide in the middle half. The goal is a habitable attic space with minimum obstructions and maximum usable area. There are interior bearing walls along the short dimension of the house every 16 to 24 feet the length of the house (a total of four plus the end walls). The ceiling joists for the floor below will be 2 X 12 parallel to the long ridge line. Plan has three cross gables on the front side of the long ridge line, and some dormers on the back side of the long ridge line. The structural problems seem to be a bear. If I use self supporting ridge beams, the spacing of the interior bearing walls means the spans between the posts (located at the bearing walls) are so large that a tremendous ridge girder is required. Something like 7 X 16 or 18 LVL according to the span tables. I shudder to think what this would cost for materials and installation, even in 16 to 24 ft sections. So that brings me to using ridge boards and rafter ties.
The layout I described means that most of the rafters on the long gable are not in opposing pairs, since the rafters that join the back wall of the house would not have a rafter to tie to on the front of the house, due to the cross gables that are part of the habitable space space. Similarly, the rafters on the cross gables would only be in opposing pairs at floor level at the front of the house, for a few pairs. There is no way to meet the requirements for the number and spacing of rafter ties in this situation. And even if the joist were run perpendicular to the long ridge line, they would then end up parallel to the cross gable rafters. So how does one use rafter ties in this kind of design?
I have one possible alternative, but am not sure if it would meet code. That is to frame the attic floor as though it was the beginning of a third story, with double top plate from the floor below, 2 X 12 joists and then 3/4 plywood sheathing, with a 2 X 6 sill plate around the perimeter of the house. The rafters would then be toe nailed to the sill plate. I would think a continuous plywood sheathed floor would tie the opposing walls together better than rafter ties. At that point the only structural issue might be uplifting which would be dealt with by strapping of the rafters to the exterior wall framing.
Does anyone have any thoughts or advice about how to handle all of this?
